I am going through the RF-PHY certification process for the CC26x2 chipset from below link:
However, the document suggests that there are two tools which can be use for HCI communication while using the "Host Test" firmware image. One is Btool and second is HCI Tester. We have sufficient information on using the BTool and how it works. However, there is not enough documentation on using the HCI Test tool while using the TI CC26x2 Launchpad.
Can you suggest whether TI HCI Tester application support CC26x2R1 launch pad or the chipset itself? If yes, we're I can find the documentation on having a specific XML file and Script file for CC26x2R1 to be used with the HCI Tester application?
Mehul
