Part Number: CC2642R
Hi team,
Our customer plans to develop the next generation system with CC2642R and customer investigating Low Power mode control. They are using Network Processor Interface (NPI).
According to CC13x2/CC26x2 SDK BLE5-Stack User’s Guide( http://dev.ti.com/tirex/explore/content/simplelink_cc13x2_26x2_sdk_3_10_00_53/docs/ble5stack/ble_user_guide/html/ble-stack-common/npi-index.html ), there is following description, as you know
In order to properly manage the power domains of the device, there must be a way for an external host to wake the network processor from low power modes. This is done through the inclusion of the following pins (MRFY[CTS] /SRDY[RTS]).
Since customer would like to know more detail information for this, customer is also reading TRM (5.7.1 cc26_aon_event_AON_EVENT_RMAP Registers, 7.6 Power Modes, 13.10.3 cc26_mcu_ioc_map1 Registers) . however, customer is not able to find helpful descriptions about MRFY[CTS] /SRDY[RTS].
- Customer would like to implement Low Power mode, should they use MRFY[CTS] /SRDY[RTS] ?
- Regarding to current system, customer does not assign CTS/RTS for UART I/F. this means, there is possibility that CC26x2 is not able to enter Low Power Mode. Is that correct?
I believe External Host is able to wake CC26x2 from low power mode by GPIO. In this case, what user’s guide should customer refer to? Could you evaporate it, please?
Miyazaki
