LAUNCHXL-CC26X2R1: Extended advertiser device not detected
Part Number: LAUNCHXL-CC26X2R1
My setup is Samsung S10 (configured as advertiser with extended advertising) and CC26X2R1 board (flashed with host test). On the CC26X2R1 I am using Btool application.
For advertiser I've set more settings:
  • Primary PHY - LE 1M / LE Coded
  • Secondary PHY - LE 1M / LE 2M / LE Coded
After sending the GAPScan_Enable() command , I expect that the Samsung S10 appears in the scan list but is not happening .
I should set different scan settings for scanning for extended advertising devices?
Thank you and waiting for your response !
Robert
