Hi Clement,
I used the BTool for the test, but it seems that I've failed to manage to establish a connection with the phone as well as with the simple peripheral, I saved two log files.
1. host_test connect simple_periperal
[1] : <Tx> - 10:10:00.832 -Type : 0x01 (Command) -OpCode : 0xFE09 (GAP_EstablishLinkRequest) -Data Length : 0x09 (9) byte(s) HighDutyCycle : 0x00 (0) (Disable) WhiteList : 0x00 (0) (Disable) AddrTypePeer : 0x00 (0) (ADDRTYPE_PUBLIC) PeerAddr : F0:F8:F2:DA:33:45 Dump(Tx): 0000:01 09 FE 09 00 00 00 45 33 DA F2 F8 F0 .......E3.... -------------------------------------------------------------------- [2] : <Rx> - 10:10:00.840 -Type : 0x04 (Event) -EventCode : 0x00FF (HCI_LE_ExtEvent) -Data Length : 0x06 (6) bytes(s) Event : 0x067F (1663) (GAP_HCI_ExtentionCommandStatus) Status : 0x00 (0) (SUCCESS) OpCode : 0xFE09 (GAP_EstablishLinkRequest) DataLength : 0x00 (0) Dump(Rx): 0000:04 FF 06 7F 06 00 09 FE 00 ......... -------------------------------------------------------------------- [3] : <Rx> - 10:10:00.851 -Type : 0x04 (Event) -EventCode : 0x00FF (HCI_LE_ExtEvent) -Data Length : 0x14 (20) bytes(s) Event : 0x0605 (1541) (GAP_EstablishLink) Status : 0x09 (9) (NV_ITEM_UNINIT) DevAddrType : 0x00 (0) (ADDRTYPE_PUBLIC) DevAddr : F0:F8:F2:DA:33:45 ConnHandle : 0x0000 (0) ConnRole : 0x00 (0) ( ProfileRoles Bit Mask Is Not Set) ConnInterval : 0x0000 (0) ConnLatency : 0x0000 (0) ConnTimeout : 0x0000 (0) ClockAccuracy : 0x00 (0) Dump(Rx): 0000:04 FF 14 05 06 09 00 45 33 DA F2 F8 F0 00 00 00 .......E3....... 0010:00 00 00 00 00 00 00 ....... -------------------------------------------------------------------- [4] : <Tx> - 10:10:00.884 -Type : 0x01 (Command) -OpCode : 0x2022 (HCI_LE_SetDataLength) -Data Length : 0x06 (6) byte(s) Handle : 0x0000 (0) TxOctets : 0x00FB (251) TxTime : 0x0848 (2120) Dump(Tx): 0000:01 22 20 06 00 00 FB 00 48 08 ." .....H. -------------------------------------------------------------------- [5] : <Rx> - 10:10:00.913 -Type : 0x04 (Event) -EventCode : 0x000E (HCI_CommandCompleteEvent) -Data Length : 0x06 (6) bytes(s) Packets : 0x01 (1) OpCode : 0x2022 (HCI_LE_SetDataLength) Status : 0x02 (2) (UNKNOWN_CONN_ID) Handle : 0x0000 (0) Dump(Rx): 0000:04 0E 06 01 22 20 02 00 00 ...." ... --------------------------------------------------------------------
2. host_test connect android phone
[1] : <Tx> - 10:27:39.985 -Type : 0x01 (Command) -OpCode : 0xFE04 (GAP_DeviceDiscoveryRequest) -Data Length : 0x03 (3) byte(s) Mode : 0x03 (3) (All) ActiveScan : 0x01 (1) (Enable) WhiteList : 0x00 (0) (All) Dump(Tx): 0000:01 04 FE 03 03 01 00 ....... -------------------------------------------------------------------- [2] : <Rx> - 10:27:39.996 -Type : 0x04 (Event) -EventCode : 0x00FF (HCI_LE_ExtEvent) -Data Length : 0x06 (6) bytes(s) Event : 0x067F (1663) (GAP_HCI_ExtentionCommandStatus) Status : 0x00 (0) (SUCCESS) OpCode : 0xFE04 (GAP_DeviceDiscoveryRequest) DataLength : 0x00 (0) Dump(Rx): 0000:04 FF 06 7F 06 00 04 FE 00 ......... -------------------------------------------------------------------- [3] : <Rx> - 10:27:40.007 -Type : 0x04 (Event) -EventCode : 0x00FF (HCI_LE_ExtEvent) -Data Length : 0x29 (41) bytes(s) Event : 0x060D (1549) (GAP_DeviceInformation) Status : 0x00 (0) (SUCCESS) EventType : 0x02 (2) (SCANABLE_UNDIRECT_AD) AddrType : 0x01 (1) (ADDRTYPE_RANDOM) Addr : 50:55:F7:D6:69:EA Rssi : 0xA0 (160) DataLength : 0x1C (28) Data : 03:03:9F:FE:17:16:9F:FE:00:00:00:00:00:00:00:00: 00:00:00:00:00:00:00:00:00:00:00:00 Dump(Rx): 0000:04 FF 29 0D 06 00 02 01 EA 69 D6 F7 55 50 A0 1C ..)......i..UP.. 0010:03 03 9F FE 17 16 9F FE 00 00 00 00 00 00 00 00 ................ 0020:00 00 00 00 00 00 00 00 00 00 00 00 ............ -------------------------------------------------------------------- [4] : <Rx> - 10:27:40.055 -Type : 0x04 (Event) -EventCode : 0x00FF (HCI_LE_ExtEvent) -Data Length : 0x1C (28) bytes(s) Event : 0x060D (1549) (GAP_DeviceInformation) Status : 0x00 (0) (SUCCESS) EventType : 0x03 (3) (NON_CONN_UNDIRECT_AD) AddrType : 0x01 (1) (ADDRTYPE_RANDOM) Addr : 31:C9:8C:77:39:A2 Rssi : 0xA5 (165) DataLength : 0x0F (15) Data : 02:01:1A:0B:FF:4C:00:09:06:03:0F:0A:0A:0A:6E Dump(Rx): 0000:04 FF 1C 0D 06 00 03 01 A2 39 77 8C C9 31 A5 0F .........9w..1.. 0010:02 01 1A 0B FF 4C 00 09 06 03 0F 0A 0A 0A 6E .....L........n -------------------------------------------------------------------- [5] : <Rx> - 10:27:40.087 -Type : 0x04 (Event) -EventCode : 0x00FF (HCI_LE_ExtEvent) -Data Length : 0x1E (30) bytes(s) Event : 0x060D (1549) (GAP_DeviceInformation) Status : 0x00 (0) (SUCCESS) EventType : 0x00 (0) (CONN_UNDIRECT_AD) AddrType : 0x01 (1) (ADDRTYPE_RANDOM) Addr : 73:A8:73:B9:05:08 Rssi : 0xD3 (211) DataLength : 0x11 (17) Data : 02:01:02:0A:09:4D:69:20:50:68:6F:6E:65:32:02:0A: 01 Dump(Rx): 0000:04 FF 1E 0D 06 00 00 01 08 05 B9 73 A8 73 D3 11 ...........s.s.. 0010:02 01 02 0A 09 4D 69 20 50 68 6F 6E 65 32 02 0A .....Mi Phone2.. 0020:01 . -------------------------------------------------------------------- [6] : <Rx> - 10:27:40.110 -Type : 0x04 (Event) -EventCode : 0x00FF (HCI_LE_ExtEvent) -Data Length : 0x2B (43) bytes(s) Event : 0x060D (1549) (GAP_DeviceInformation) Status : 0x00 (0) (SUCCESS) EventType : 0x03 (3) (NON_CONN_UNDIRECT_AD) AddrType : 0x01 (1) (ADDRTYPE_RANDOM) Addr : EE:14:28:2A:BE:0B Rssi : 0xB4 (180) DataLength : 0x1E (30) Data : 02:01:06:1A:FF:4C:00:02:15:F7:82:6D:A6:4F:A2:4E: 98:80:24:BC:5B:71:E0:89:3E:45:D2:3B:71:B3 Dump(Rx): 0000:04 FF 2B 0D 06 00 03 01 0B BE 2A 28 14 EE B4 1E ..+.......*(.... 0010:02 01 06 1A FF 4C 00 02 15 F7 82 6D A6 4F A2 4E .....L.....m.O.N 0020:98 80 24 BC 5B 71 E0 89 3E 45 D2 3B 71 B3 ..$.[q..>E.;q. -------------------------------------------------------------------- [7] : <Rx> - 10:27:40.120 -Type : 0x04 (Event) -EventCode : 0x00FF (HCI_LE_ExtEvent) -Data Length : 0x2B (43) bytes(s) Event : 0x060D (1549) (GAP_DeviceInformation) Status : 0x00 (0) (SUCCESS) EventType : 0x00 (0) (CONN_UNDIRECT_AD) AddrType : 0x00 (0) (ADDRTYPE_PUBLIC) Addr : DC:0D:30:00:04:06 Rssi : 0xB5 (181) DataLength : 0x1E (30) Data : 02:01:06:1A:FF:4C:00:02:15:FD:A5:06:93:A4:E2:4F: B1:AF:CF:C6:EB:07:64:78:25:27:51:65:C1:B5 Dump(Rx): 0000:04 FF 2B 0D 06 00 00 00 06 04 00 30 0D DC B5 1E ..+........0.... 0010:02 01 06 1A FF 4C 00 02 15 FD A5 06 93 A4 E2 4F .....L.........O 0020:B1 AF CF C6 EB 07 64 78 25 27 51 65 C1 B5 ......dx%'Qe.. -------------------------------------------------------------------- [8] : <Rx> - 10:27:40.131 -Type : 0x04 (Event) -EventCode : 0x00FF (HCI_LE_ExtEvent) -Data Length : 0x27 (39) bytes(s) Event : 0x060D (1549) (GAP_DeviceInformation) Status : 0x00 (0) (SUCCESS) EventType : 0x04 (4) (SCAN_RESPONSE) AddrType : 0x00 (0) (ADDRTYPE_PUBLIC) Addr : DC:0D:30:00:04:06 Rssi : 0xB5 (181) DataLength : 0x1A (26) Data : 0E:16:F0:FF:1A:02:09:02:DC:0D:30:00:04:06:64:0A: 09:46:53:43:5F:42:50:31:30:36 Dump(Rx): 0000:04 FF 27 0D 06 00 04 00 06 04 00 30 0D DC B5 1A ..'........0.... 0010:0E 16 F0 FF 1A 02 09 02 DC 0D 30 00 04 06 64 0A ..........0...d. 0020:09 46 53 43 5F 42 50 31 30 36 .FSC_BP106 -------------------------------------------------------------------- [9] : <Rx> - 10:27:40.154 -Type : 0x04 (Event) -EventCode : 0x00FF (HCI_LE_ExtEvent) -Data Length : 0x1E (30) bytes(s) Event : 0x060D (1549) (GAP_DeviceInformation) Status : 0x00 (0) (SUCCESS) EventType : 0x00 (0) (CONN_UNDIRECT_AD) AddrType : 0x01 (1) (ADDRTYPE_RANDOM) Addr : 65:02:8E:C8:E1:3B Rssi : 0xA9 (169) DataLength : 0x11 (17) Data : 02:01:1A:02:0A:0C:0A:FF:4C:00:10:05:51:1C:04:6B: 25 Dump(Rx): 0000:04 FF 1E 0D 06 00 00 01 3B E1 C8 8E 02 65 A9 11 ........;....e.. 0010:02 01 1A 02 0A 0C 0A FF 4C 00 10 05 51 1C 04 6B ........L...Q..k 0020:25 % -------------------------------------------------------------------- [10] : <Rx> - 10:27:40.164 -Type : 0x04 (Event) -EventCode : 0x00FF (HCI_LE_ExtEvent) -Data Length : 0x2C (44) bytes(s) Event : 0x060D (1549) (GAP_DeviceInformation) Status : 0x00 (0) (SUCCESS) EventType : 0x00 (0) (CONN_UNDIRECT_AD) AddrType : 0x00 (0) (ADDRTYPE_PUBLIC) Addr : DC:0D:30:00:04:00 Rssi : 0xC9 (201) DataLength : 0x1F (31) Data : 02:01:06:1B:FF:00:00:BE:AC:93:6A:5C:2A:16:C2:4B: 84:B7:A8:83:90:46:6B:59:17:00:00:00:00:00:00 Dump(Rx): 0000:04 FF 2C 0D 06 00 00 00 00 04 00 30 0D DC C9 1F ..,........0.... 0010:02 01 06 1B FF 00 00 BE AC 93 6A 5C 2A 16 C2 4B ..........j\*..K 0020:84 B7 A8 83 90 46 6B 59 17 00 00 00 00 00 00 .....FkY....... -------------------------------------------------------------------- [11] : <Rx> - 10:27:40.186 -Type : 0x04 (Event) -EventCode : 0x00FF (HCI_LE_ExtEvent) -Data Length : 0x10 (16) bytes(s) Event : 0x060D (1549) (GAP_DeviceInformation) Status : 0x00 (0) (SUCCESS) EventType : 0x00 (0) (CONN_UNDIRECT_AD) AddrType : 0x00 (0) (ADDRTYPE_PUBLIC) Addr : DC:0D:30:00:1F:A5 Rssi : 0xB4 (180) DataLength : 0x03 (3) Data : 02:01:06 Dump(Rx): 0000:04 FF 10 0D 06 00 00 00 A5 1F 00 30 0D DC B4 03 ...........0.... 0010:02 01 06 ... -------------------------------------------------------------------- [12] : <Rx> - 10:27:40.197 -Type : 0x04 (Event) -EventCode : 0x00FF (HCI_LE_ExtEvent) -Data Length : 0x27 (39) bytes(s) Event : 0x060D (1549) (GAP_DeviceInformation) Status : 0x00 (0) (SUCCESS) EventType : 0x04 (4) (SCAN_RESPONSE) AddrType : 0x00 (0) (ADDRTYPE_PUBLIC) Addr : DC:0D:30:00:1F:A5 Rssi : 0xB4 (180) DataLength : 0x1A (26) Data : 0E:16:F0:FF:1A:02:05:02:DC:0D:30:00:1F:A5:64:0A: 09:46:53:43:5F:42:50:31:30:36 Dump(Rx): 0000:04 FF 27 0D 06 00 04 00 A5 1F 00 30 0D DC B4 1A ..'........0.... 0010:0E 16 F0 FF 1A 02 05 02 DC 0D 30 00 1F A5 64 0A ..........0...d. 0020:09 46 53 43 5F 42 50 31 30 36 .FSC_BP106 -------------------------------------------------------------------- [13] : <Rx> - 10:27:40.218 -Type : 0x04 (Event) -EventCode : 0x00FF (HCI_LE_ExtEvent) -Data Length : 0x2B (43) bytes(s) Event : 0x060D (1549) (GAP_DeviceInformation) Status : 0x00 (0) (SUCCESS) EventType : 0x00 (0) (CONN_UNDIRECT_AD) AddrType : 0x00 (0) (ADDRTYPE_PUBLIC) Addr : DC:0D:30:00:04:13 Rssi : 0xB2 (178) DataLength : 0x1E (30) Data : 02:01:06:1A:FF:4C:00:02:15:D5:46:DF:97:47:57:47: EF:BE:09:3E:2D:CB:DD:0C:77:30:00:04:13:B5 Dump(Rx): 0000:04 FF 2B 0D 06 00 00 00 13 04 00 30 0D DC B2 1E ..+........0.... 0010:02 01 06 1A FF 4C 00 02 15 D5 46 DF 97 47 57 47 .....L....F..GWG 0020:EF BE 09 3E 2D CB DD 0C 77 30 00 04 13 B5 ...>-...w0.... -------------------------------------------------------------------- [14] : <Rx> - 10:27:40.229 -Type : 0x04 (Event) -EventCode : 0x00FF (HCI_LE_ExtEvent) -Data Length : 0x1E (30) bytes(s) Event : 0x060D (1549) (GAP_DeviceInformation) Status : 0x00 (0) (SUCCESS) EventType : 0x00 (0) (CONN_UNDIRECT_AD) AddrType : 0x00 (0) (ADDRTYPE_PUBLIC) Addr : DC:56:E7:47:C7:CA Rssi : 0xA5 (165) DataLength : 0x11 (17) Data : 02:01:1A:02:0A:0C:0A:FF:4C:00:10:05:0D:14:46:E7: 21 Dump(Rx): 0000:04 FF 1E 0D 06 00 00 00 CA C7 47 E7 56 DC A5 11 ..........G.V... 0010:02 01 1A 02 0A 0C 0A FF 4C 00 10 05 0D 14 46 E7 ........L.....F. 0020:21 ! -------------------------------------------------------------------- [15] : <Rx> - 10:27:40.315 -Type : 0x04 (Event) -EventCode : 0x00FF (HCI_LE_ExtEvent) -Data Length : 0x28 (40) bytes(s) Event : 0x060D (1549) (GAP_DeviceInformation) Status : 0x00 (0) (SUCCESS) EventType : 0x00 (0) (CONN_UNDIRECT_AD) AddrType : 0x00 (0) (ADDRTYPE_PUBLIC) Addr : DC:0D:30:4F:43:D6 Rssi : 0xB1 (177) DataLength : 0x1B (27) Data : 02:01:06:03:03:AA:FE:13:16:AA:FE:10:D4:03:67:6F: 6F:2E:67:6C:2F:50:48:4E:53:64:6D Dump(Rx): 0000:04 FF 28 0D 06 00 00 00 D6 43 4F 30 0D DC B1 1B ..(......CO0.... 0010:02 01 06 03 03 AA FE 13 16 AA FE 10 D4 03 67 6F ..............go 0020:6F 2E 67 6C 2F 50 48 4E 53 64 6D o.gl/PHNSdm -------------------------------------------------------------------- [16] : <Rx> - 10:27:40.335 -Type : 0x04 (Event) -EventCode : 0x00FF (HCI_LE_ExtEvent) -Data Length : 0x26 (38) bytes(s) Event : 0x060D (1549) (GAP_DeviceInformation) Status : 0x00 (0) (SUCCESS) EventType : 0x03 (3) (NON_CONN_UNDIRECT_AD) AddrType : 0x01 (1) (ADDRTYPE_RANDOM) Addr : C3:C6:21:6E:7B:EA Rssi : 0xC3 (195) DataLength : 0x19 (25) Data : 02:01:06:03:03:AA:FE:11:16:AA:FE:20:00:0B:4B:15: 00:17:26:DB:47:1F:DC:9F:3C Dump(Rx): 0000:04 FF 26 0D 06 00 03 01 EA 7B 6E 21 C6 C3 C3 19 ..&......{n!.... 0010:02 01 06 03 03 AA FE 11 16 AA FE 20 00 0B 4B 15 ........... ..K. 0020:00 17 26 DB 47 1F DC 9F 3C ..&.G...< -------------------------------------------------------------------- [17] : <Rx> - 10:27:40.475 -Type : 0x04 (Event) -EventCode : 0x00FF (HCI_LE_ExtEvent) -Data Length : 0x20 (32) bytes(s) Event : 0x060D (1549) (GAP_DeviceInformation) Status : 0x00 (0) (SUCCESS) EventType : 0x00 (0) (CONN_UNDIRECT_AD) AddrType : 0x01 (1) (ADDRTYPE_RANDOM) Addr : E0:49:98:87:E4:73 Rssi : 0xB5 (181) DataLength : 0x13 (19) Data : 02:01:06:0F:16:6A:FE:02:08:01:04:5E:F4:52:74:62: 6E:39:5A Dump(Rx): 0000:04 FF 20 0D 06 00 00 01 73 E4 87 98 49 E0 B5 13 .. .....s...I... 0010:02 01 06 0F 16 6A FE 02 08 01 04 5E F4 52 74 62 .....j.....^.Rtb 0020:6E 39 5A n9Z -------------------------------------------------------------------- [18] : <Rx> - 10:27:40.487 -Type : 0x04 (Event) -EventCode : 0x00FF (HCI_LE_ExtEvent) -Data Length : 0x2A (42) bytes(s) Event : 0x060D (1549) (GAP_DeviceInformation) Status : 0x00 (0) (SUCCESS) EventType : 0x03 (3) (NON_CONN_UNDIRECT_AD) AddrType : 0x01 (1) (ADDRTYPE_RANDOM) Addr : EB:20:98:61:87:D1 Rssi : 0xAF (175) DataLength : 0x1D (29) Data : 02:01:06:03:03:AA:FE:15:16:AA:FE:00:DC:F7:82:6D: A6:4F:A2:4E:98:80:24:50:4D:52:59:57:4F Dump(Rx): 0000:04 FF 2A 0D 06 00 03 01 D1 87 61 98 20 EB AF 1D ..*.......a. ... 0010:02 01 06 03 03 AA FE 15 16 AA FE 00 DC F7 82 6D ...............m 0020:A6 4F A2 4E 98 80 24 50 4D 52 59 57 4F .O.N..$PMRYWO -------------------------------------------------------------------- [19] : <Rx> - 10:27:40.605 -Type : 0x04 (Event) -EventCode : 0x00FF (HCI_LE_ExtEvent) -Data Length : 0x2B (43) bytes(s) Event : 0x060D (1549) (GAP_DeviceInformation) Status : 0x00 (0) (SUCCESS) EventType : 0x00 (0) (CONN_UNDIRECT_AD) AddrType : 0x00 (0) (ADDRTYPE_PUBLIC) Addr : DC:0D:30:00:07:D0 Rssi : 0xD2 (210) DataLength : 0x1E (30) Data : 02:01:06:1A:FF:4C:00:02:15:D5:46:DF:97:47:57:47: EF:BE:09:3E:2D:CB:DD:0C:77:30:00:07:D0:B5 Dump(Rx): 0000:04 FF 2B 0D 06 00 00 00 D0 07 00 30 0D DC D2 1E ..+........0.... 0010:02 01 06 1A FF 4C 00 02 15 D5 46 DF 97 47 57 47 .....L....F..GWG 0020:EF BE 09 3E 2D CB DD 0C 77 30 00 07 D0 B5 ...>-...w0.... -------------------------------------------------------------------- [20] : <Rx> - 10:27:40.690 -Type : 0x04 (Event) -EventCode : 0x00FF (HCI_LE_ExtEvent) -Data Length : 0x20 (32) bytes(s) Event : 0x060D (1549) (GAP_DeviceInformation) Status : 0x00 (0) (SUCCESS) EventType : 0x00 (0) (CONN_UNDIRECT_AD) AddrType : 0x01 (1) (ADDRTYPE_RANDOM) Addr : CC:C2:42:F0:F2:CF Rssi : 0xC3 (195) DataLength : 0x13 (19) Data : 02:01:06:0F:16:6A:FE:02:08:01:04:63:F4:52:74:5A: 75:51:73 Dump(Rx): 0000:04 FF 20 0D 06 00 00 01 CF F2 F0 42 C2 CC C3 13 .. ........B.... 0010:02 01 06 0F 16 6A FE 02 08 01 04 63 F4 52 74 5A .....j.....c.RtZ 0020:75 51 73 uQs -------------------------------------------------------------------- [21] : <Rx> - 10:27:40.830 -Type : 0x04 (Event) -EventCode : 0x00FF (HCI_LE_ExtEvent) -Data Length : 0x2B (43) bytes(s) Event : 0x060D (1549) (GAP_DeviceInformation) Status : 0x00 (0) (SUCCESS) EventType : 0x00 (0) (CONN_UNDIRECT_AD) AddrType : 0x00 (0) (ADDRTYPE_PUBLIC) Addr : DC:0D:30:00:04:1F Rssi : 0xBD (189) DataLength : 0x1E (30) Data : 02:01:06:1A:FF:4C:00:02:15:D5:46:DF:97:47:57:47: EF:BE:09:3E:2D:CB:DD:0C:77:30:00:04:1F:B5 Dump(Rx): 0000:04 FF 2B 0D 06 00 00 00 1F 04 00 30 0D DC BD 1E ..+........0.... 0010:02 01 06 1A FF 4C 00 02 15 D5 46 DF 97 47 57 47 .....L....F..GWG 0020:EF BE 09 3E 2D CB DD 0C 77 30 00 04 1F B5 ...>-...w0.... -------------------------------------------------------------------- [22] : <Rx> - 10:27:40.840 -Type : 0x04 (Event) -EventCode : 0x00FF (HCI_LE_ExtEvent) -Data Length : 0x27 (39) bytes(s) Event : 0x060D (1549) (GAP_DeviceInformation) Status : 0x00 (0) (SUCCESS) EventType : 0x04 (4) (SCAN_RESPONSE) AddrType : 0x00 (0) (ADDRTYPE_PUBLIC) Addr : DC:0D:30:00:04:1F Rssi : 0xBD (189) DataLength : 0x1A (26) Data : 0E:16:F0:FF:1A:02:09:02:DC:0D:30:00:04:1F:64:0A: 09:46:53:43:5F:42:50:31:30:36 Dump(Rx): 0000:04 FF 27 0D 06 00 04 00 1F 04 00 30 0D DC BD 1A ..'........0.... 0010:0E 16 F0 FF 1A 02 09 02 DC 0D 30 00 04 1F 64 0A ..........0...d. 0020:09 46 53 43 5F 42 50 31 30 36 .FSC_BP106 -------------------------------------------------------------------- [23] : <Rx> - 10:27:40.914 -Type : 0x04 (Event) -EventCode : 0x00FF (HCI_LE_ExtEvent) -Data Length : 0x1E (30) bytes(s) Event : 0x060D (1549) (GAP_DeviceInformation) Status : 0x00 (0) (SUCCESS) EventType : 0x00 (0) (CONN_UNDIRECT_AD) AddrType : 0x01 (1) (ADDRTYPE_RANDOM) Addr : 64:38:12:E5:83:B2 Rssi : 0xA3 (163) DataLength : 0x11 (17) Data : 02:01:1A:02:0A:0C:0A:FF:4C:00:10:05:4E:1C:50:4A: E4 Dump(Rx): 0000:04 FF 1E 0D 06 00 00 01 B2 83 E5 12 38 64 A3 11 ............8d.. 0010:02 01 1A 02 0A 0C 0A FF 4C 00 10 05 4E 1C 50 4A ........L...N.PJ 0020:E4 . -------------------------------------------------------------------- [24] : <Rx> - 10:27:41.044 -Type : 0x04 (Event) -EventCode : 0x00FF (HCI_LE_ExtEvent) -Data Length : 0x2B (43) bytes(s) Event : 0x060D (1549) (GAP_DeviceInformation) Status : 0x00 (0) (SUCCESS) EventType : 0x03 (3) (NON_CONN_UNDIRECT_AD) AddrType : 0x01 (1) (ADDRTYPE_RANDOM) Addr : FF:86:C6:4E:81:1D Rssi : 0xC3 (195) DataLength : 0x1E (30) Data : 02:01:06:1A:FF:4C:00:02:15:F7:82:6D:A6:4F:A2:4E: 98:80:24:BC:5B:71:E0:89:3E:50:0B:F3:41:B3 Dump(Rx): 0000:04 FF 2B 0D 06 00 03 01 1D 81 4E C6 86 FF C3 1E ..+.......N..... 0010:02 01 06 1A FF 4C 00 02 15 F7 82 6D A6 4F A2 4E .....L.....m.O.N 0020:98 80 24 BC 5B 71 E0 89 3E 50 0B F3 41 B3 ..$.[q..>P..A. -------------------------------------------------------------------- [25] : <Rx> - 10:27:41.184 -Type : 0x04 (Event) -EventCode : 0x00FF (HCI_LE_ExtEvent) -Data Length : 0x2B (43) bytes(s) Event : 0x060D (1549) (GAP_DeviceInformation) Status : 0x00 (0) (SUCCESS) EventType : 0x00 (0) (CONN_UNDIRECT_AD) AddrType : 0x00 (0) (ADDRTYPE_PUBLIC) Addr : DC:0D:30:00:1F:B3 Rssi : 0xC8 (200) DataLength : 0x1E (30) Data : 02:01:06:1A:FF:4C:00:02:15:FD:A5:06:93:A4:E2:4F: B1:AF:CF:C6:EB:07:64:78:25:30:00:1B:D8:B5 Dump(Rx): 0000:04 FF 2B 0D 06 00 00 00 B3 1F 00 30 0D DC C8 1E ..+........0.... 0010:02 01 06 1A FF 4C 00 02 15 FD A5 06 93 A4 E2 4F .....L.........O 0020:B1 AF CF C6 EB 07 64 78 25 30 00 1B D8 B5 ......dx%0.... -------------------------------------------------------------------- [26] : <Rx> - 10:27:41.195 -Type : 0x04 (Event) -EventCode : 0x00FF (HCI_LE_ExtEvent) -Data Length : 0x27 (39) bytes(s) Event : 0x060D (1549) (GAP_DeviceInformation) Status : 0x00 (0) (SUCCESS) EventType : 0x04 (4) (SCAN_RESPONSE) AddrType : 0x00 (0) (ADDRTYPE_PUBLIC) Addr : DC:0D:30:00:1F:B3 Rssi : 0xC8 (200) DataLength : 0x1A (26) Data : 0E:16:F0:FF:1A:02:05:02:DC:0D:30:00:1F:B3:64:0A: 09:46:53:43:5F:42:50:31:30:36 Dump(Rx): 0000:04 FF 27 0D 06 00 04 00 B3 1F 00 30 0D DC C8 1A ..'........0.... 0010:0E 16 F0 FF 1A 02 05 02 DC 0D 30 00 1F B3 64 0A ..........0...d. 0020:09 46 53 43 5F 42 50 31 30 36 .FSC_BP106 -------------------------------------------------------------------- [27] : <Rx> - 10:27:44.679 -Type : 0x04 (Event) -EventCode : 0x00FF (HCI_LE_ExtEvent) -Data Length : 0x27 (39) bytes(s) Event : 0x060D (1549) (GAP_DeviceInformation) Status : 0x00 (0) (SUCCESS) EventType : 0x00 (0) (CONN_UNDIRECT_AD) AddrType : 0x00 (0) (ADDRTYPE_PUBLIC) Addr : DC:0D:30:00:04:1F Rssi : 0xC3 (195) DataLength : 0x1A (26) Data : 02:01:06:03:03:AA:FE:11:16:AA:FE:20:00:0B:CB:80: 00:01:95:87:CF:00:01:75:F2:00 Dump(Rx): 0000:04 FF 27 0D 06 00 00 00 1F 04 00 30 0D DC C3 1A ..'........0.... 0010:02 01 06 03 03 AA FE 11 16 AA FE 20 00 0B CB 80 ........... .... 0020:00 01 95 87 CF 00 01 75 F2 00 .......u.. -------------------------------------------------------------------- [28] : <Rx> - 10:27:46.312 -Type : 0x04 (Event) -EventCode : 0x00FF (HCI_LE_ExtEvent) -Data Length : 0x1E (30) bytes(s) Event : 0x060D (1549) (GAP_DeviceInformation) Status : 0x00 (0) (SUCCESS) EventType : 0x00 (0) (CONN_UNDIRECT_AD) AddrType : 0x01 (1) (ADDRTYPE_RANDOM) Addr : 64:38:12:E5:83:B2 Rssi : 0xA5 (165) DataLength : 0x11 (17) Data : 02:01:1A:02:0A:0C:0A:FF:4C:00:10:05:0E:1C:50:4A: E4 Dump(Rx): 0000:04 FF 1E 0D 06 00 00 01 B2 83 E5 12 38 64 A5 11 ............8d.. 0010:02 01 1A 02 0A 0C 0A FF 4C 00 10 05 0E 1C 50 4A ........L.....PJ 0020:E4 . -------------------------------------------------------------------- [29] : <Rx> - 10:27:46.442 -Type : 0x04 (Event) -EventCode : 0x00FF (HCI_LE_ExtEvent) -Data Length : 0x1E (30) bytes(s) Event : 0x060D (1549) (GAP_DeviceInformation) Status : 0x00 (0) (SUCCESS) EventType : 0x00 (0) (CONN_UNDIRECT_AD) AddrType : 0x01 (1) (ADDRTYPE_RANDOM) Addr : 64:38:12:E5:83:B2 Rssi : 0xA5 (165) DataLength : 0x11 (17) Data : 02:01:1A:02:0A:0C:0A:FF:4C:00:10:05:06:1C:50:4A: E4 Dump(Rx): 0000:04 FF 1E 0D 06 00 00 01 B2 83 E5 12 38 64 A5 11 ............8d.. 0010:02 01 1A 02 0A 0C 0A FF 4C 00 10 05 06 1C 50 4A ........L.....PJ 0020:E4 . -------------------------------------------------------------------- [30] : <Rx> - 10:27:49.833 -Type : 0x04 (Event) -EventCode : 0x00FF (HCI_LE_ExtEvent) -Data Length : 0x2B (43) bytes(s) Event : 0x060D (1549) (GAP_DeviceInformation) Status : 0x00 (0) (SUCCESS) EventType : 0x00 (0) (CONN_UNDIRECT_AD) AddrType : 0x00 (0) (ADDRTYPE_PUBLIC) Addr : DC:0D:30:00:04:1F Rssi : 0xC2 (194) DataLength : 0x1E (30) Data : 02:01:06:1A:FF:4C:00:02:15:FD:A5:06:93:A4:E2:4F: B1:AF:CF:C6:EB:07:64:78:25:27:51:65:C1:B5 Dump(Rx): 0000:04 FF 2B 0D 06 00 00 00 1F 04 00 30 0D DC C2 1E ..+........0.... 0010:02 01 06 1A FF 4C 00 02 15 FD A5 06 93 A4 E2 4F .....L.........O 0020:B1 AF CF C6 EB 07 64 78 25 27 51 65 C1 B5 ......dx%'Qe.. -------------------------------------------------------------------- [31] : <Rx> - 10:27:50.246 -Type : 0x04 (Event) -EventCode : 0x00FF (HCI_LE_ExtEvent) -Data Length : 0xA4 (164) bytes(s) Event : 0x0601 (1537) (GAP_DeviceDiscoveryDone) Status : 0x00 (0) (SUCCESS) NumDevs : 0x14 (20) Device #0 EventType : 0x02 (2) (SCANABLE_UNDIRECT_AD) AddrType : 0x01 (1) (ADDRTYPE_RANDOM) Addr : 50:55:F7:D6:69:EA Device #1 EventType : 0x03 (3) (NON_CONN_UNDIRECT_AD) AddrType : 0x01 (1) (ADDRTYPE_RANDOM) Addr : 31:C9:8C:77:39:A2 Device #2 EventType : 0x00 (0) (CONN_UNDIRECT_AD) AddrType : 0x01 (1) (ADDRTYPE_RANDOM) Addr : 73:A8:73:B9:05:08 Device #3 EventType : 0x03 (3) (NON_CONN_UNDIRECT_AD) AddrType : 0x01 (1) (ADDRTYPE_RANDOM) Addr : EE:14:28:2A:BE:0B Device #4 EventType : 0x00 (0) (CONN_UNDIRECT_AD) AddrType : 0x00 (0) (ADDRTYPE_PUBLIC) Addr : DC:0D:30:00:04:06 Device #5 EventType : 0x00 (0) (CONN_UNDIRECT_AD) AddrType : 0x01 (1) (ADDRTYPE_RANDOM) Addr : 65:02:8E:C8:E1:3B Device #6 EventType : 0x00 (0) (CONN_UNDIRECT_AD) AddrType : 0x00 (0) (ADDRTYPE_PUBLIC) Addr : DC:0D:30:00:04:00 Device #7 EventType : 0x00 (0) (CONN_UNDIRECT_AD) AddrType : 0x00 (0) (ADDRTYPE_PUBLIC) Addr : DC:0D:30:00:1F:A5 Device #8 EventType : 0x00 (0) (CONN_UNDIRECT_AD) AddrType : 0x00 (0) (ADDRTYPE_PUBLIC) Addr : DC:0D:30:00:04:13 Device #9 EventType : 0x00 (0) (CONN_UNDIRECT_AD) AddrType : 0x00 (0) (ADDRTYPE_PUBLIC) Addr : DC:56:E7:47:C7:CA Device #10 EventType : 0x00 (0) (CONN_UNDIRECT_AD) AddrType : 0x00 (0) (ADDRTYPE_PUBLIC) Addr : DC:0D:30:4F:43:D6 Device #11 EventType : 0x03 (3) (NON_CONN_UNDIRECT_AD) AddrType : 0x01 (1) (ADDRTYPE_RANDOM) Addr : C3:C6:21:6E:7B:EA Device #12 EventType : 0x00 (0) (CONN_UNDIRECT_AD) AddrType : 0x01 (1) (ADDRTYPE_RANDOM) Addr : E0:49:98:87:E4:73 Device #13 EventType : 0x03 (3) (NON_CONN_UNDIRECT_AD) AddrType : 0x01 (1) (ADDRTYPE_RANDOM) Addr : EB:20:98:61:87:D1 Device #14 EventType : 0x00 (0) (CONN_UNDIRECT_AD) AddrType : 0x00 (0) (ADDRTYPE_PUBLIC) Addr : DC:0D:30:00:07:D0 Device #15 EventType : 0x00 (0) (CONN_UNDIRECT_AD) AddrType : 0x01 (1) (ADDRTYPE_RANDOM) Addr : CC:C2:42:F0:F2:CF Device #16 EventType : 0x00 (0) (CONN_UNDIRECT_AD) AddrType : 0x00 (0) (ADDRTYPE_PUBLIC) Addr : DC:0D:30:00:04:1F Device #17 EventType : 0x00 (0) (CONN_UNDIRECT_AD) AddrType : 0x01 (1) (ADDRTYPE_RANDOM) Addr : 64:38:12:E5:83:B2 Device #18 EventType : 0x03 (3) (NON_CONN_UNDIRECT_AD) AddrType : 0x01 (1) (ADDRTYPE_RANDOM) Addr : FF:86:C6:4E:81:1D Device #19 EventType : 0x00 (0) (CONN_UNDIRECT_AD) AddrType : 0x00 (0) (ADDRTYPE_PUBLIC) Addr : DC:0D:30:00:1F:B3 Dump(Rx): 0000:04 FF A4 01 06 00 14 02 01 EA 69 D6 F7 55 50 03 ..........i..UP. 0010:01 A2 39 77 8C C9 31 00 01 08 05 B9 73 A8 73 03 ..9w..1.....s.s. 0020:01 0B BE 2A 28 14 EE 00 00 06 04 00 30 0D DC 00 ...*(.......0... 0030:01 3B E1 C8 8E 02 65 00 00 00 04 00 30 0D DC 00 .;....e.....0... 0040:00 A5 1F 00 30 0D DC 00 00 13 04 00 30 0D DC 00 ....0.......0... 0050:00 CA C7 47 E7 56 DC 00 00 D6 43 4F 30 0D DC 03 ...G.V....CO0... 0060:01 EA 7B 6E 21 C6 C3 00 01 73 E4 87 98 49 E0 03 ..{n!....s...I.. 0070:01 D1 87 61 98 20 EB 00 00 D0 07 00 30 0D DC 00 ...a. ......0... 0080:01 CF F2 F0 42 C2 CC 00 00 1F 04 00 30 0D DC 00 ....B.......0... 0090:01 B2 83 E5 12 38 64 03 01 1D 81 4E C6 86 FF 00 .....8d....N.... 00A0:00 B3 1F 00 30 0D DC ....0.. -------------------------------------------------------------------- [32] : <Tx> - 10:28:22.870 -Type : 0x01 (Command) -OpCode : 0xFE09 (GAP_EstablishLinkRequest) -Data Length : 0x09 (9) byte(s) HighDutyCycle : 0x00 (0) (Disable) WhiteList : 0x00 (0) (Disable) AddrTypePeer : 0x01 (1) (ADDRTYPE_RANDOM) PeerAddr : 73:A8:73:B9:05:08 Dump(Tx): 0000:01 09 FE 09 00 00 01 08 05 B9 73 A8 73 ..........s.s -------------------------------------------------------------------- [33] : <Rx> - 10:28:22.890 -Type : 0x04 (Event) -EventCode : 0x00FF (HCI_LE_ExtEvent) -Data Length : 0x06 (6) bytes(s) Event : 0x067F (1663) (GAP_HCI_ExtentionCommandStatus) Status : 0x00 (0) (SUCCESS) OpCode : 0xFE09 (GAP_EstablishLinkRequest) DataLength : 0x00 (0) Dump(Rx): 0000:04 FF 06 7F 06 00 09 FE 00 ......... -------------------------------------------------------------------- [34] : <Rx> - 10:28:22.900 -Type : 0x04 (Event) -EventCode : 0x00FF (HCI_LE_ExtEvent) -Data Length : 0x14 (20) bytes(s) Event : 0x0605 (1541) (GAP_EstablishLink) Status : 0x09 (9) (NV_ITEM_UNINIT) DevAddrType : 0x01 (1) (ADDRTYPE_RANDOM) DevAddr : 73:A8:73:B9:05:08 ConnHandle : 0x0000 (0) ConnRole : 0x00 (0) ( ProfileRoles Bit Mask Is Not Set) ConnInterval : 0x0000 (0) ConnLatency : 0x0000 (0) ConnTimeout : 0x0000 (0) ClockAccuracy : 0x00 (0) Dump(Rx): 0000:04 FF 14 05 06 09 01 08 05 B9 73 A8 73 00 00 00 ..........s.s... 0010:00 00 00 00 00 00 00 ....... -------------------------------------------------------------------- [35] : <Tx> - 10:28:22.935 -Type : 0x01 (Command) -OpCode : 0x2022 (HCI_LE_SetDataLength) -Data Length : 0x06 (6) byte(s) Handle : 0x0000 (0) TxOctets : 0x00FB (251) TxTime : 0x0848 (2120) Dump(Tx): 0000:01 22 20 06 00 00 FB 00 48 08 ." .....H. -------------------------------------------------------------------- [36] : <Rx> - 10:28:22.964 -Type : 0x04 (Event) -EventCode : 0x000E (HCI_CommandCompleteEvent) -Data Length : 0x06 (6) bytes(s) Packets : 0x01 (1) OpCode : 0x2022 (HCI_LE_SetDataLength) Status : 0x02 (2) (UNKNOWN_CONN_ID) Handle : 0x0000 (0) Dump(Rx): 0000:04 0E 06 01 22 20 02 00 00 ...." ... --------------------------------------------------------------------
Jerry
