I used a receiver, combined the two sample project uart2callback_CC1352P_2_LAUNCHXL_tirtos_ccs and rfPacketRx_CC1352P_2_LAUNCHXL_tirtos_ccs .
I want to send the received data to the PC through uart port for display. I use another wireless generator to send the data with rfListenBeforeTalk_CC1352P_2_LAUNCHXL_tirtos_ccs,
the receiver can receive the data in debuge state, but uart does not send the data to PC, the debug must be stopped once, and the data is sent .Once when it is running, and then the receiver cannot receive the data. .
How can I solve this problem?
It is the source I wrote.
/***** Function definitions *****/
void *mainThread(void *arg0)
RF_Params rfParams;
RF_Params_init(&rfParams);
const char echoPrompt[] = "Echoing characters:\r\n";
UART2_Params uartParams;
int32_t semStatus;
uint32_t status = UART2_STATUS_SUCCESS;
uint8_t bknumUart;
/* Open LED pins */
ledPinHandle = PIN_open(&ledPinState, pinTable);
if (ledPinHandle == NULL)
while(1);
if( RFQueue_defineQueue(&dataQueue,
rxDataEntryBuffer,
sizeof(rxDataEntryBuffer),
NUM_DATA_ENTRIES,
MAX_LENGTH + NUM_APPENDED_BYTES))
/* Failed to allocate space for all data entries */
while(1);
/* Modify CMD_PROP_RX command for application needs */
/* Set the Data Entity queue for received data */
RF_cmdPropRx.pQueue = &dataQueue;
/* Discard ignored packets from Rx queue */
RF_cmdPropRx.rxConf.bAutoFlushIgnored = 1;
/* Discard packets with CRC error from Rx queue */
RF_cmdPropRx.rxConf.bAutoFlushCrcErr = 1;
/* Implement packet length filtering to avoid PROP_ERROR_RXBUF */
RF_cmdPropRx.maxPktLen = MAX_LENGTH;
RF_cmdPropRx.pktConf.bRepeatOk = 1;
RF_cmdPropRx.pktConf.bRepeatNok = 1;
/* Request access to the radio */
#if defined(DeviceFamily_CC26X0R2)
rfHandle = RF_open(&rfObject, &RF_prop, (RF_RadioSetup*)&RF_cmdPropRadioSetup, &rfParams);
#else
rfHandle = RF_open(&rfObject, &RF_prop, (RF_RadioSetup*)&RF_cmdPropRadioDivSetup, &rfParams);
#endif// DeviceFamily_CC26X0R2
/* Set the frequency */
RF_postCmd(rfHandle, (RF_Op*)&RF_cmdFs, RF_PriorityNormal, NULL, 0);
/* Enter RX mode and stay forever in RX */
RF_EventMask terminationReason = RF_runCmd(rfHandle, (RF_Op*)&RF_cmdPropRx,
RF_PriorityNormal, &callback,
RF_EventRxEntryDone);
switch(terminationReason)
case RF_EventLastCmdDone:
// A stand-alone radio operation command or the last radio
// operation command in a chain finished.
break;
case RF_EventCmdCancelled:
// Command cancelled before it was started; it can be caused
// by RF_cancelCmd() or RF_flushCmd().
break;
case RF_EventCmdAborted:
// Abrupt command termination caused by RF_cancelCmd() or
// RF_flushCmd().
break;
case RF_EventCmdStopped:
// Graceful command termination caused by RF_cancelCmd() or
// RF_flushCmd().
break;
default:
// Uncaught error event
while(1);
uint32_t cmdStatus = ((volatile RF_Op*)&RF_cmdPropRx)->status;
switch(cmdStatus)
case PROP_DONE_OK:
// Packet received with CRC OK
break;
case PROP_DONE_RXERR:
// Packet received with CRC error
break;
case PROP_DONE_RXTIMEOUT:
// Observed end trigger while in sync search
break;
case PROP_DONE_BREAK:
// Observed end trigger while receiving packet when the command is
// configured with endType set to 1
break;
case PROP_DONE_ENDED:
// Received packet after having observed the end trigger; if the
// command is configured with endType set to 0, the end trigger
// will not terminate an ongoing reception
break;
case PROP_DONE_STOPPED:
// received CMD_STOP after command started and, if sync found,
// packet is received
break;
case PROP_DONE_ABORT:
// Received CMD_ABORT after command started
break;
case PROP_ERROR_RXBUF:
// No RX buffer large enough for the received data available at
// the start of a packet
break;
case PROP_ERROR_RXFULL:
// Out of RX buffer space during reception in a partial read
break;
case PROP_ERROR_PAR:
// Observed illegal parameter
break;
case PROP_ERROR_NO_SETUP:
// Command sent without setting up the radio in a supported
// mode using CMD_PROP_RADIO_SETUP or CMD_RADIO_SETUP
break;
case PROP_ERROR_NO_FS:
// Command sent without the synthesizer being programmed
break;
case PROP_ERROR_RXOVF:
// RX overflow observed during operation
break;
default:
// Uncaught error event - these could come from the
// pool of states defined in rf_mailbox.h
while(1);
/* Create semaphore */
semStatus = sem_init(&sem, 0, 0);
if (semStatus != 0) {
/* Error creating semaphore */
while (1);
/* Create a UART in CALLBACK read mode */
UART2_Params_init(&uartParams);
uartParams.readMode = UART2_Mode_CALLBACK;
uartParams.readCallback = callbackFxn;
uartParams.baudRate = 2000000;
uart = UART2_open(CONFIG_UART2_0, &uartParams);
if (uart == NULL) {
/* UART2_open() failed */
while (1);
/* Pass NULL for bytesWritten since it's not used in this example */
UART2_write(uart, echoPrompt, sizeof(echoPrompt), NULL);
numBytesRead = 0;
/* Pass NULL for bytesRead since it's not used in this example */
// status = UART2_readTimeout(uart, &input,1, NULL,1);
if (status != UART2_STATUS_SUCCESS) {
/* UART2_read() failed */
while (1);
while(1){
/* Do not write until read callback executes */
// sem_wait(&sem);
if (numUart > 0) {
bknumUart = numUart;
numUart = 0;
// status = UART2_write(uart, input, 100, NULL);
UART_polling(bknumUart);
bknumUart = 0;
/* UART2_write() failed */
while (1);
while(rfnum > 0){
UART2_write(uart, &rfrxpacket[rfrp], 1, NULL);
rfnum--;
rfrp++;
if(rfrp >= MAX_BUFF_LENGTH){
rfrp = 0;
void callback(RF_Handle h, RF_CmdHandle ch, RF_EventMask e)
int i;
if (e & RF_EventRxEntryDone)
/* Toggle pin to indicate RX */
PIN_setOutputValue(ledPinHandle, CONFIG_PIN_RLED,
!PIN_getOutputValue(CONFIG_PIN_RLED));
/* Get current unhandled data entry */
currentDataEntry = RFQueue_getDataEntry();
/* Handle the packet data, located at ¤tDataEntry->data:
* - Length is the first byte with the current configuration
* - Data starts from the second byte */
packetLength = *(uint8_t*)(¤tDataEntry->data);
packetDataPointer = (uint8_t*)(¤tDataEntry->data + 1);
/* Copy the payload + the status byte to the packet variable */
for(i= 0;i< packetLength + 1 ; i++){
rfrxpacket[rfwp] = *(packetDataPointer + i);
rfwp++;
rfnum++;
if(rfwp >= MAX_BUFF_LENGTH){
rfwp = 0;
RFQueue_nextEntry();
