Hi TI team,
I have a project use CC8520,When the fixed frequency modulation is 2.404Ghz and 2.460Ghz, the following waveform will appear,What is the reason for this?
Hello switch,
I am looking into the issue and getting in touch with experts for the software.
Are you using custom hardware or just a TI product when experiencing this?
Beste
From the CC85xx Family User's Guide, the RFT_TXTST_PN command requires you to be in production test operation and you should do a device reset before and after using the command.
If you want to use this command, can you try it with the PPW Commander "Command and Monitoring" tool and report your results?
Daniel
