I would like to define the best compromise between sensitivity and decoding error depending on the radio parameters configured on the chip.
How do I define the BER of a radio configuration for a CC2500?
Hello gregoire,
Packet error rate (PER) is related to bit error rate (BER) by PER = 1 (1-BER)packet_length. You can evaluate PER with Example libraries, SimpliciTI, or Smart RF Studio tests. Here are some relevant E2E threads concerning how to monitor the BER:
https://e2e.ti.com/f/1/t/3786113
https://e2e.ti.com/f/1/t/3641710
https://e2e.ti.com/f/1/t/3804721
You can use the PER tests to then evaluate whether modifying the MDMCFG2.DEM_DCFILT_OFF and TEST1/2 registers (for sensitivity levels) will improve your system.
Ryan
Hello Ryan,
Your link https://e2e.ti.com/f/1/t/3786113... don't works
If I understand your method is experimental, it is not possible to define the BER theoretically?
I apologize for the broken links. Here they are again (and corrected in the other E2E response):
https://e2e.ti.com/f/1/t/1024299
https://e2e.ti.com/f/1/t/984852
https://e2e.ti.com/f/1/t/1029025
Bit error rate must be measured, it cannot be theorized using only sensitivity parameters. There are RF receive results with sensitivity levels for a 1% PER provided in the datasheet.
Ryan
