Other Parts Discussed in Thread: CC1352P
I wish to try implementing spread spectrum and long-range mode under a private protocol, and test sensitivity. Specifically, this means achieving DSSS=8, FEC = 1/2, LRM, using 2-FSK modulation. However, after searching through forums and technical documents, I am unsure how to achieve this in smartrf by adjusting values and override settings, especially for the configuration of DSSS, as there are many different opinions. For instance, I'm not certain if using HW_REG_OVERRIDE(0x5068,0x030C) actually activates DSSS. Could you please provide me with a detailed set of instructions so I can implement the aforementioned mode? And what is the proper register value for different DSSS under CC2652P?
Another question is, when I using CC1352P launchpad to test WB-DSSS mode, the tested sensitivity using attenuator is -115 but datasheet shows -121, I'm wondering how did you test sensitivity, which result is more convencing?
