Good day
I bought 1000pcs RF-HDT-DVBE-N2 (in one original pack) from TI stock, however i found two different marking,pls see picture
could you pls check are there any function difference?
Good day
While I'm checking, can you take a picture of the shipped package? It will help us trace the product.
I have checked internally with our expert. The marking represents the UID of the transponder which you can also read out from the memory. Each transponder has a different UID number so that the laser marking is different for each transponder. The bottom line is that there is no difference in the functionality.
Below is the comment from our expert.
To the differences in the share - it is one time the front side and the other time the backside, and from the molding tool it looks slightly different.
The difference between the two transponders is that the marking is one time on the frontside on the other time on the backside.
So I would expect that it has flipped during the production process or it has been taken out by an operator and put flipped back in.
No difference in the functionality.
