CC2650EM-4XS-RD: Unable to shift the Stack image location(ICALL_STACK0_ADDR ) in flash
Part Number: CC2650EM-4XS-RD
Other Parts Discussed in Thread: TIMAC, CC2650
Hello All,
I am unable to locate the Frontier tool, can some one guide where can i find the Frontier tool to configure the memory automatically.
I have an issue that my configuration uses ICALL_STACK0_ADDR as 0x9000.
My application image size has increased and would like to shift the stack image. If i change ICALL_STACK0_ADDR to anything else(say 0xA000). The application and stack images correctly gets loaded in the Flash at their respective configured addresses(stack = 0xA0000) however the Application and stack images doesn't interact.
I have made the linker config settings for the application and stack as below:
Environment :CC26504xs custom board, IAR Workbench version - 7.40.2.8570, TIMAC - 1.5.2, TIRTOS - 2.11.01.09.
Am i missing anything here.
Please suggest.
Best regards
Naveen
This is how my cc26xx_timac_stack_release.icf looks like:
Filename: cc26xx_timac_stack.icf
Revised: $Date: 2014-05-14 14:50:19 -0700 (Wed, 14 May 2014) $
Revision: $Revision: 38545 $
Description: IAR ARM Linker Configuration File - BLE Stack
Note: Code stack and heap are allocated by the Application/RTOS build.
Imported Symbols
Note: Linker defines are located in the IAR IDE project using --config_def
in Options->Linker->Extra Options, or placed in Options->Linker->
Config->Configuration file symbol definitions.
CCxxxx: Device Name (e.g. CC2650).
FLASH_ONLY_BUILD: Build full TIMAC stack in flash only memory.
FLASH_ROM_BUILD: Build Flash portion of TIMAC stack to work with ROM code.
ROM_BUILD: Build ROM portion of TIMAC stack.
COMMON_ROM_BUILD: Build of common ROM code.
TEST_ROM_IN_FLASH: Build ROM code in Flash memory to test.
ICALL_STACK0_ADDR: Start address of flash only and flash ROM builds.
ICALL_RAM0_ADDR: Start address of RAM.
Exported Symbols
Note: Can be used as externs in C code.
ROM_BASE_ADDR: Location of start of ROM (where RT Init is expected).
RAM_BASE_ADDR: Location of start of RAM (for ICall and JT pointers).
COMMON_RAM_BASE_ADDR: Location of start of RAM (for ICall and JT pointers).
PAGE_SIZE: Size of Flash sector, in bytes.
NUM_SNV_PAGES: Number of sectors used for Simple NV.
Copyright 2013-2014 Texas Instruments Incorporated. All rights reserved.
IMPORTANT: Your use of this Software is limited to those specific rights
granted under the terms of a software license agreement between the user
who downloaded the software, his/her employer (which must be your employer)
and Texas Instruments Incorporated (the "License"). You may not use this
Software unless you agree to abide by the terms of the License. The License
limits your use, and you acknowledge, that the Software may not be modified,
copied or distributed unless embedded on a Texas Instruments microcontroller
or used solely and exclusively in conjunction with a Texas Instruments radio
frequency transceiver, which is integrated into your product. Other than for
the foregoing purpose, you may not use, reproduce, copy, prepare derivative
works of, modify, distribute, perform, display or sell this Software and/or
its documentation for any purpose.
YOU FURTHER ACKNOWLEDGE AND AGREE THAT THE SOFTWARE AND DOCUMENTATION ARE
PROVIDED “AS IS” WITHOUT WARRANTY OF ANY KIND, EITHER EXPRESS OR IMPLIED,
INCLUDING WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY, TITLE,
NON-INFRINGEMENT AND FITNESS FOR A PARTICULAR PURPOSE. IN NO EVENT SHALL
TEXAS INSTRUMENTS OR ITS LICENSORS BE LIABLE OR OBLIGATED UNDER CONTRACT,
NEGLIGENCE, STRICT LIABILITY, CONTRIBUTION, BREACH OF WARRANTY, OR OTHER
LEGAL EQUITABLE THEORY ANY DIRECT OR INDIRECT DAMAGES OR EXPENSES
INCLUDING BUT NOT LIMITED TO ANY INCIDENTAL, SPECIAL, INDIRECT, PUNITIVE
OR CONSEQUENTIAL DAMAGES, LOST PROFITS OR LOST DATA, COST OF PROCUREMENT
OF SUBSTITUTE GOODS, TECHNOLOGY, SERVICES, OR ANY CLAIMS BY THIRD PARTIES
(INCLUDING BUT NOT LIMITED TO ANY DEFENSE THEREOF), OR OTHER SIMILAR COSTS.
Should you have any questions regarding your right to use this Software,
contact Texas Instruments Incorporated at www.TI.com.
// Memory Sizes
// Chameleon
if ( isdefinedsymbol(CC2650) )
define symbol RAM_SIZE = 0x00005000; // 20K
define symbol FLASH_SIZE = 0x00020000; // 128K
define symbol ROM_SIZE = 0x0001C000; // 115K
// Default
else
define symbol RAM_SIZE = 0x00004000; // 16K
define symbol ROM_SIZE = 0x00018000; // 96K
// Memory Definitions
// CM3 FW
define symbol FW_START = 0x10000000;
define symbol FW_END = 0x10004BFF;
define symbol FLASH_END_MODIFY = 0x1BFFF;
// ROM
if ( isdefinedsymbol(COMMON_ROM_BUILD) )
if ( isdefinedsymbol(TEST_ROM_IN_FLASH) )
define symbol ROM_START = 0x0001A000;
define symbol ROM_END = 0x0001EFFF;
else // ROM code is in ROM memory
define symbol ROM_START = 0x10014C00;
define symbol ROM_END = 0x10019FFF;
else if ( isdefinedsymbol(ROM_BUILD) )
define symbol ROM_START = 0x00010000;
define symbol ROM_END = 0x00019FFF;
define symbol ROM_START = 0x1000E000;
define symbol ROM_END = 0x10014BFF;
else // not a ROM build
define symbol ROM_END = 0x0001FFFF;
// export the ROM base address
if ( isdefinedsymbol(ROM_BUILD) || isdefinedsymbol(COMMON_ROM_BUILD) )
define symbol ROM_BASE_ADDR = ROM_START+1;
export symbol ROM_BASE_ADDR;
// RAM
if ( isdefinedsymbol(FLASH_ONLY_BUILD) )
if ( isdefinedsymbol(ICALL_RAM0_ADDR) )
define symbol RAM_START = ICALL_RAM0_ADDR;
else // default
define symbol RAM_START = 0x20002A00;
define symbol RAM_END = 0x20004FFF;
else // default
define symbol RAM_END = 0x20003FFF;
else if ( isdefinedsymbol(COMMON_ROM_BUILD) )
define symbol RAM_START = 0x20004F2C;
else // default
define symbol RAM_START = 0x20003200;
define symbol RAM_END = 0x200032FF;
define symbol COMMON_RAM_BASE_ADDR = RAM_START;
export symbol COMMON_RAM_BASE_ADDR;
define symbol RAM_START = 0x20004A14;
define symbol RAM_END = 0x20004EFF;
else
define symbol RAM_START = 0x20003300;
define symbol RAM_BASE_ADDR = RAM_START;
export symbol RAM_BASE_ADDR;
else if ( isdefinedsymbol(FLASH_ROM_BUILD) )
else
define symbol RAM_START = 0x20004200;
else
else
define symbol RAM_END = 0x200031FF;
else // unknown build
define symbol RAM_START = 0xFFFFFFFF;
define symbol RAM_END = 0xFFFFFFFF;
// Flash
define symbol PAGE_SIZE = 0x1000;
export symbol PAGE_SIZE;
define symbol NUM_RESERVED_PAGES = 1;
define symbol RESERVED_SIZE = (NUM_RESERVED_PAGES * PAGE_SIZE);
define symbol NUM_SNV_PAGES = 2;
export symbol NUM_SNV_PAGES;
define symbol SNV_SIZE = (NUM_SNV_PAGES * PAGE_SIZE);
define symbol SNV_START = (FLASH_SIZE - (RESERVED_SIZE + SNV_SIZE));
define symbol SNV_END = (SNV_START + SNV_SIZE - 1);
if ( isdefinedsymbol(ICALL_STACK0_ADDR) )
define symbol FLASH_START = ICALL_STACK0_ADDR;
else // default
define symbol FLASH_START = 0x0000A000;
define symbol FLASH_END = (SNV_START - 1);
else if ( isdefinedsymbol(ROM_ONLY_BUILD) || isdefinedsymbol(COMMON_ROM_BUILD) )
define symbol FLASH_START = ROM_START;
define symbol FLASH_END = ROM_END;
else // default
define symbol FLASH_END = (ROM_START-1);
// define symbol FLASH_END = FLASH_END_MODIFY ;
define symbol FLASH_END = (0x10000 -1);
define symbol FLASH_START = 0xFFFFFFFF;
define symbol FLASH_END = 0xFFFFFFFF;
// ROM Revision Number
define symbol ROM_CRC_SIZE = 2;
define symbol ROM_REV_SIZE = 2;
define symbol ROM_REV_START = ROM_END - (ROM_CRC_SIZE + 1);
define symbol ROM_REV_END = ROM_REV_START + ROM_REV_SIZE - 1;
// Memory Regions
define memory mem with size = 4G;
define region FW = mem:[from FW_START to FW_END];
define region ROM = mem:[from ROM_START to ROM_END];
define region FLASH = mem:[from FLASH_START to FLASH_END];
define region RAM = mem:[from RAM_START to RAM_END];
define region SNV_FLASH = mem:[from SNV_START to SNV_END];
define region ROM_REV = mem:[from ROM_REV_START to ROM_REV_END];
// Flash Software Entry Point
if ( isdefinedsymbol(FLASH_ONLY_BUILD) || isdefinedsymbol(FLASH_ROM_BUILD) )
place at start of FLASH { readonly section EntrySection };
// Memory Placement
// For ROM: C Runtime, Checksum, ROM Revision Number, Flash JT, and FPB.
place in ROM { readonly };
place in RAM { readwrite };
// ROM C Runtime Routine
place at start of ROM { ro section .romRuntimeInit };
keep { section .romRuntimeInit };
// Checksum
place at end of ROM { ro section .checksum };
keep { section .checksum };
place at start of ROM_REV { ro section .rom_rev };
keep { section .rom_rev };
// ICall Functions and R2F and R2R Flash Jump Table Location Pointers
place at start of RAM { section .ramInitTable };
keep { section .ramInitTable };
else // !ROM_BUILD && !COMMON_ROM_BUILD
place in FLASH { readonly };
// Simple NV
define block .snv_mem with size=SNV_SIZE, alignment=4 { ro section .snv_mem };
place at start of SNV_FLASH { block .snv_mem };
keep { ro section .snv_mem };
// Initialization
initialize by copy { readwrite };
else
initialize by copy with packing = packbits { readwrite };
do not initialize
section .noinit,
section .stack,
