CC2560B: How to remove part of request app launch in IAP2Info
Part Number: CC2560B
I have a project using CC2560B.
I have an issue with iPhone regarding Request App Launch.
A customer's app doesn't support app launch feature, so in the firmware that feature should be removed.
I am not sure how to remove that part.
Can I just fill with zeros like below in IAP2Info?
Thank you.
static const unsigned char IAP2Info[] =
   /*                      Parameter: Name (utf8)                       */
     0x00,0x12,              /* Parameter Length (2 byte value)         */
     0x00,0x00,              /* Parameter ID: 0 - Name                  */
     'M','F','I',' ','A','c','c','e','s','s','o','r','y',0,
   /*                 Parameter: Model Identifier (utf8)                */
     0x00,0x0D,              /* Parameter Length (2 byte value)         */
     0x00,0x01,              /* Parameter ID: 1 - Model Identifier      */
     'M','y',' ','M','o','d','e','l',0,
   /*                   Parameter: Manufacturer (utf8)                  */
     0x00,0x0E,              /* Parameter Length (2 byte value)         */
     0x00,0x02,              /* Parameter ID: 2 - Manufacturer          */
     'D','e','m','o',' ','C','o','r','p',0,
   /*                   Parameter: Serial Number (utf8)                 */
     0x00,0x03,              /* Parameter ID: 3 - Serial Number         */
     '1','2','3','4','5','6','7','8','9',0,
   /*                  Parameter: Firmware Version (utf8)               */
     0x00,0x0A,              /* Parameter Length (2 byte value)         */
     0x00,0x04,              /* Parameter ID: 4 - Acc. Firmware Version */
     '1','.','0','.','0',0,
   /*                  Parameter: Hardware Version (utf8)               */
     0x00,0x05,              /* Parameter ID: 5 - Acc. Hardware Version */
     '2','.','0','.','0',0,
   /*            Parameter: Messages Sent By Accessory (blob)           */
     //0x00,0x06,              /* Parameter Length (2 byte value)         */
     //0x00,0x06,              /* Parameter ID: 6 - Messages Sent By Acc  */
     //0xEA,0x02,              /* Message: 0xEA02 - App Launch            */
     0x00,0x00,              /* Parameter ID: 6 - Messages Sent By Acc  */
     0x00,0x00,              /* Message: 0xEA02 - App Launch            */
   /*          Parameter: Messages Received From Device (blob)          */
     0x00,0x08,              /* Parameter Length (2 byte value)         */
     0x00,0x07,              /* Parameter ID: 7 - Messages Received     */
                             /*                   From Device           */
     0xEA,0x00,              /* Msg: External Accessory Protocol Start  */
     0xEA,0x01,              /* Msg: External Accessory Protocol Stop   */
   /*                Parameter: Power Source Type (enum)                */
     0x00,0x05,              /* Parameter Length (2 byte value)         */
     0x00,0x08,              /* Parameter ID: 8 - Power Source Type     */
     0x00,                   /* Power Source Type: 0 (None)             */
   /*       Parameter: Maximum Current Drawn From Device (uint16)       */
     0x00,0x09,              /* Parameter ID: 9 - Max Current Drawn     */
     0x00,0x00,              /* Maximum Current Drawn: 0 mA             */
   /*       Parameter Group: Supported External Accessory Protocol      */
     0x00,0x20,              /* Parameter Group Length (2 byte value)   */
     0x00,0x0A,              /* Param. Group ID: Supported EA Protocol  */
     /*  Parameter: External Accessory Protocol Identifier (uint8)      */
     0x00,0x00,              /* Parameter ID: 0 - Protocol Identifier   */
     0x01,                   /* Protocol Identifier: 1                  */
     /*     Parameter: External Accessory Protocol Name (utf8)          */
     0x00,0x01,              /* Parameter ID: 1 - Protocol Name         */
     'c','o','m','.','d','e','m','o','.','d','a','t','a',0,
     /*  Parameter: External Accessory Protocol Match Action (enum)     */
     0x00,0x02,              /* Parameter ID: 2 - Match Action          */
     0x00,                   /* The device will not attempt to find a   */
                             /* matching app, nor will there be a "Find */
                             /* App For This Accessory" button in       */
                             /* Settings > General > About > Accessory. */
   /*                         End Parameter Group                       */
     0x00,0x23,              /* Parameter Group Length (2 byte value)   */
     0x02,                   /* Protocol Identifier: 2                  */
     0x00,0x15,              /* Parameter Length (2 byte value)         */
     'c','o','m','.','d','e','m','o','.','c','o','n','t','r','o','l',0,
   /*              Parameter: App Match Team ID (utf8)                */
     0x00,0x0F,              /* Parameter Length (2 byte value)         */
     0x00,0x0b,              /* Parameter ID: 11 - Current Language     */
     '1','2','3','4','5','A','B','C','D','E',0,
   /*                Parameter: Current Language (utf8)                 */
     0x00,0x07,              /* Parameter Length (2 byte value)         */
     0x00,0x0C,              /* Parameter ID: 12 - Current Language     */
     'e','n',0,
   /*               Parameter: Supported Languages (utf8)               */
     0x00,0x0D,              /* Parameter ID: 13 - Supported Languages  */
     'e','n',0,
