Other Parts Discussed in Thread: RI-TRP-DR2B,
The RF430F5978 differs in communication structure and bit timing from MPT.
(2) Or can you introduce a Transponder IC that has the same communication structure as MPT?
Hello Junk-kil,
we do not offer a transponder IC that is compatible with the Multipage transponder.
Also the RF430F5978 is completely different and can not be made compatible with configuration settings.
What is your reason for looking for a IC instead of using the MPT? Is the compatibility to the MPT a fix requirement?
Helfried
Hello Jung-kil,
if you cannot change the reader protocol and have fix the protocol for the MPT transponder it is not possible.
Helfried
Hello Jung-kil,
I haven’t heard back from you for a while, so this tread is being closed. If you wish to continue the discussion, please post a reply with an update below (or create a new thread).
Helfried
