As title, if possible disable BLE function in bts file??
or can disable BLE by HCI command?
Austin
Austin
Hi Austin,
You can use the HCI_VS_LE_Enable command. Check the wiki below for details.
BLE is disabled by default so it doesn't make sense to have a disable command in the BTS file.
https://processors.wiki.ti.com/index.php/CC256x_VS_HCI_Commands#HCI_VS_LE_Enable_.280xFD5B.29
Jesu
Jesu:
Does WL8 BTS support this HCI_VS_LE_Enable command?
I can't find it in HCItester.
Austin
Hi Austin,
It's in HCI VS Commands drop down in the command library in HCI tester.
Jesu
Hi Jesu:
I checked wl18xx bts service pack 4.5. there is no this command. May I know your wl18xx BT service pack version?
Thanks.
Austin
Hi Austin,
Sorry for the delay. I've been dealing with some high priority tasks. When you asked about the BLE enable command I thought you mean the command library window in the HCITester tool. I don't see any BLE enable in the WiLink service pack. You should still be able to use the HCI command I mentioned even though it is not in the service pack by default. Have you tried looking at our SPPLE demo to see how if it enables BLE in the Bluetopia stack? I don't have access to a Linux machine currently so I cannot check this for you.
-Jesus
