Other Parts Discussed in Thread: CC1125, WMBUS
Hi TI Experts,
I have some questions about CC1125 Register 「TOC_CFG」 settings
About 「TOC_CFG.TOC_PRE_SYNC_BLOCKLEN」:
When TOC_LIMIT = 0
(a ) At what time will TOC be started?
(b ) What the differences between the setting 000 to 101? How can I observe the effects between the setting 000 to 101?
(c ) What will it do if I set a large integration window ,ex 256 symbols, but CC1125 receive less than 256 symbols before sync word is found(PKT_SYNC_RXTX asserted)
When TOC_LIMIT != 0
(d ) What does the it mean:「Symbol by Symbol Timing Error Proportional Scale Factor」? What the differences between the setting x00 to x11? How can I observe the effects between the settings x00 to x11?
(e ) What does the setting “1xx” and the word “after sync found ” means?
About 「TOC_CFG.TOC_POST_SYNC_BLOCKLEN」
When TOC_LIMIT = 0
(f ) What the differences between the setting 000 to 101? How can I observe the effects between the setting 000 to 101?
(g ) What will it do if I set a large integration window ,ex 256 symbols, but CC1125 receive less than 256 symbols at the End of Packet?
When TOC_LIMIT != 0
(h ) What does the it mean:「Integral scale factor」? What the differences between these to those in 「TOC_CFG.TOC_PRE_SYNC_BLOCKLEN」?
(i ) What does the setting “1xx” and the word “after sync found ” means?
Do you have documents explaining more details about these registers?
Tarker
