Part Number: CC2545
Hi all,
I was designed 2 different boards with cc2545 chips.
In one board(Board X) I used CC2545 chip and cc2592 PA.
In another board(Board Y) I used CC2545 Chip and Balun IC and chip antenna.
I will give Supply to Board X by Li-Ion Battery. Similarly I give constant supply to Board Y
With this two boards I designed firmware and loaded into them. I tested the range.
But I get around 30-35mts range in indoor with this two boards..
frequently failing in Outdoor. I am not getting the atleast 5mts range.
Could you please provide the solution for below queries:
1)why it was happening in outdoor?
2) this chip was designed to work in indoor only or not?
K.manikanta
---------------------------------------------------------------------------------------------------------Please click the Verify Answer button on this post if it answers your question.---------------------------------------------------------------------------------------------------------
