Part Number: LAUNCHXL-CC1352P
Dear TI technical support,
I have purchased the module, CC1352P-2, from TI. I would like to connect external antennas to the board and have the following questions:
Given the on board SMA connector, does this serve both frequency bands?
Do I need to unsolder any capacitors to use the external antenna
I have also noticed 3 separate UFL connector ports on board and would like to ask if we can use these ufl connectors to connect to one external antenna per frequency band
If yes, do we need to do any physical or software modifications to enable the use of ufl based external antennas?
Thank you!
Yours Sincerely,
Leong Hei Kern
