Part Number: RI-R6C-001A
I faced a problem when writing single block (0x21) to TI-tag using RI-R6C-001A.
Writing data is a success, but transceiver IC(RI-R6C-001A) does not send a response. (No response flags)
(The data is correct when I read the block after writing )
When I looked up the Q&A related to this problem, it was stated that the TI tag should give more than 10 ms of delay before the EOF.
As far as I know, EOF and SOF are sent by transceiver IC, not MCU. How can I handle this?
I also saw the document "LOWBAUD_WRITE_SINGLE_BLOCK_UNADDRESSED.pdf".
In this document, the DIN is changed to Low after a 40 ms delay, and who is changing this signal?
After "TRANS1", who handles 40ms delay? MCU? If so, what should the MCU do after a 40 ms delay?
Could you explain how can I get response from transceiver IC after wiring command?
