Hi everyone.
We are doing some tests with LPSTK-CC1352R with sensor and collector projects. I have one main doubt about the use of the function Ssf_setReadingClock(uint32_t readingTime), defined at ssf.h. I would like to know the reason why the readingTime parameter is set to randomNum at Jdllc_rejoin, processCoordRealign (those two at jdllc.c), processConfigRequest, jdllcJoinedCb and setRDAttrCb (those last three at sensor.c).
I can see that, at Sensor_sendMsg, readingTime is set to reportingInterval, which seems to make sense (the sensors are read at every reporting interval). However, I cannot see why it is set to randomNum in the rest of cases. I would appreciate if you could explan why readingTime is set to randomNum in those cases.
Thank you in advance and best regards,
Mario
