How could I know what SDK version was used for the factory image? Also, is there a procedure to replace the factory image?
-kel
-kel
Hi Markel,
You should be able to read the SDK version in the OAD image header. https://dev.ti.com/tirex/content/simplelink_cc13x2_26x2_sdk_5_10_00_48/docs/ble5stack/ble_user_guide/html/oad-secure/image-header.html
If you remove the factory image on the external flash, the next time the device awakens it will set the running image to the factory image.
https://dev.ti.com/tirex/explore/node?node=AGvm9KQnl2l0bnfTKlzOvQ__pTTHBmu__LATEST
