Other Parts Discussed in Thread: CC1101, CC1310
Does the SimpleLink library offer any built-in forward error correction utilities?
Using the RTOS environment on the LaunchPad, with TI compiler.
thx!
thx!
The Long Range Modes have a built in FEC.
For other datarates (up to 500 kbps before FEC) you can use dev.ti.com/.../cc1101-migration.html
No. FEC decrease the effective datarate by a factor 2 hence it's not used for the HS modes.
You mean,
FEC_rate = nonFEC_rate / 2
So, the FEC parameters are fixed?
Is it Reed-Solomon?
thx
See https://www.ti.com/lit/pdf/swra313 for CC1101 compatible FEC implementation.
Not compatible with CC1310?
The article mentions software vs hardware FEC. Does CC1310 have hardware FEC?
thx
Ok, i understand. You wrote previously that
"You can also use a CC1101 compatible FEC"
e2e.ti.com/.../3185869
