Dear TI Friend,
Question1 :
We happened to find Tx spurious emission from CC1200 (have solved it). During the debugging, we attempted to use an external supply to ensure no unwanted signal coupled in supply.
However, we do find one thing: Even we disconnected the series component, i.e. power supply for CC1200 is cut off, still there is near 3.3V power on the rail. Using evaluation board, we find IT IS the RESET_N pin seems to supply the power to the chip. Wonder if that's what it is supposed to be doing. Anyone can share some thoughts on this?
Question2:
We understand it is better off and safer to use a pull-up resistor to deal with reset pin. Right now in our development procedure, our board does not have a pull-up resistor for reset_n pin. We find when power off and on again, there is something wrong, and it is required to dowload program again to do the job. Same code working with demo board CC1200(demo board has a pull-up) seems to have no problem. Thus, we are corncerned about RESET pin. Anyone has some thoughts on this? Or how can we avoid this by software for time of being?
If I am not clear on the description, please point out.
Yuanchen Zhu
