CC430F5137: High current consumption in LPM3 compared to CC430F5147
Part Number: CC430F5137
Other Parts Discussed in Thread: CC430F5147
Following code cause high current consumption (100uA) in LPM3 with CC430F5137. Same code with CC430F5147 has a more normal consumption of 4.3uA. It is the combination of RF1 in WOR and TA0. Disabling either and CC430F5137 drops down to 4.3uA. Also removing //TA0CCTL0 |= CCIE; (*1) drops current down to 4.3uA.
What am I missing?
void main( void )
  WDTCTL = WDTPW | WDTHOLD  | WDTCNTCL;
  P1OUT = 0x00;
  P1DIR = 0xff;
  P1IES = 0x00;
  P2OUT = 0x80;
  P2DIR = 0xdf;
  P2IES = 0x00;
  P3OUT = 0x00;
  P3DIR = 0xff;
  P5OUT = 0x00;
  P5DIR = 0x03;
  PJOUT = 0x00;
  PJDIR = 0xff;
  PMMCTL0_H = 0xA5;
  SVSMHCTL  = 0;
  SVSMLCTL  = 0;  //SVSLFP;
  PMMCTL0_H = 0x00;
  // TA0
  TA0CTL  =  TASSEL__ACLK | TACLR | ID__4;
  TA0EX0  =  TAIDEX_1;
  TA0CTL |= MC__CONTINUOUS;
  PMMCTL0_H  = 0xA5;
  PMMCTL0_L  = 0; PMMHPMRE_L;      // PMMHPMRE_L=52uA, 0=200uA
  PMMCTL0_H  = 0x00;
  // RF1, Init WOR
  strobe_command(RF_SRES);
  strobe_command(RF_SNOP);
  strobe_command(RF_SCAL);
  strobe_command(RF_SIDLE);
  strobe_command(RF_SRX);
  strobe_command(RF_SWOR);
  // TA0, Start stop
  TA0CCR0 = TA0R+200;
  TA0CCTL0 |= CCIE;         // *1 cc430f5137: With 85uA,  Without 4,4uA   /  cc430f5147: With or Withoout 4,3uA
  __bis_SR_register(GIE);
  __bis_SR_register(LPM3_bits);
  P3DS  = 0x80;   // LED Strong drive
  P3OUT = 0x80;   // LED On
  while(1);
static void __attribute__((__interrupt__(TIMER0_A0_VECTOR))) _io_timerA0_ISR0 (void)    //CC0
  TA0CCTL0 &= ~(CCIE|CCIFG);
  • Hi Phil,
    It seems that the different is TIMERA interrupt. It will cause the power consumption increasing with ISR. But the is no data about the consumption.
  • Hi Allen,
    I found the cause, there is no transition directly from RX to WOR in the radio's state machine. It has to go over IDLE. If I change that, as below, I get 4.4uA even on the CC430F5137 with ISR.
