Hello.
I'm having trouble with an asynchronous transmit with clear channel assessment. It operates fine for several minutes, but eventually it fails to call the txcb. I've checked that the RF_CmdHandle returned by the RF_postCmd function is valid. The call to EasyLink_transmitCcaAsync returns EasyLink_Status_Success, but the txcb is never called after sending or failing to send the packet.
CCA parameters:
//! EASYLINK_CCA_BACKOFF_TIMEUNITS, as a power of 2
#define EASYLINK_MIN_CCA_BACKOFF_WINDOW 5 // min backoff of 8ms
//! \brief Maximum CCA back-off window in units of
#define EASYLINK_MAX_CCA_BACKOFF_WINDOW 8 // max backoff of 64ms
//! \brief The back-off time units in microseconds
#define EASYLINK_CCA_BACKOFF_TIMEUNITS 250 // 0.25ms
//! \brief RSSI threshold for Clear Channel Assessment (CCA)
#define EASYLINK_CS_RSSI_THRESHOLD_DBM -70
//! \brief Time for which the channel RSSI must remain below the specified
//! threshold for the channel to be considered idle
#define EASYLINK_CHANNEL_IDLE_TIME_US 180000 // channel must remain idle for 180ms
// Configure the EasyLink Carrier Sense Command
memset(&EasyLink_cmdPropCs, 0, sizeof(rfc_CMD_PROP_CS_t));
EasyLink_cmdPropCs.commandNo = CMD_PROP_CS;
EasyLink_cmdPropCs.rssiThr = EASYLINK_CS_RSSI_THRESHOLD_DBM;
EasyLink_cmdPropCs.numRssiBusy = 5;
EasyLink_cmdPropCs.startTrigger.triggerType = TRIG_ABSTIME;
EasyLink_cmdPropCs.condition.rule = COND_STOP_ON_TRUE; // Stop next command if this command returned TRUE,
// End causes for the CMD_PROP_CS command:
// Observed channel state Busy with csConf.busyOp = 1: PROP_DONE_BUSY TRUE
// 0bserved channel state Idle with csConf.idleOp = 1: PROP_DONE_IDLE FALSE
// Timeout trigger observed with channel state Busy: PROP_DONE_BUSY TRUE
// Timeout trigger observed with channel state Idle: PROP_DONE_IDLE FALSE
// Timeout trigger observed with channel state Invalid and csConf.timeoutRes = 0: PROP_DONE_BUSYTIMEOUT TRUE
// Timeout trigger observed with channel state Invalid and csConf.timeoutRes = 1: PROP_DONE_IDLETIMEOUT FALSE
// Received CMD_STOP after command started: PROP_DONE_STOPPED FALSE
EasyLink_cmdPropCs.csConf.bEnaRssi = 0x1; // Enable RSSI as a criterion
EasyLink_cmdPropCs.csConf.bEnaCorr = 0x1; // Enable correlation as a criterion
EasyLink_cmdPropCs.csConf.operation = 0x0; //!< \brief 0: Busy if either RSSI or correlation indicates Busy<br>
//!< 1: Busy if both RSSI and correlation indicates Busy
EasyLink_cmdPropCs.corrPeriod = 0x20; // Number of RAT ticks for a correlation observation periods (*4 for us)
EasyLink_cmdPropCs.corrConfig.numCorrBusy = 0x3; //!< \brief Number of subsequent correlation tops with maximum <code>corrPeriod</code> RAT ticks between them
//!< needed to go from Invalid to Busy
EasyLink_cmdPropCs.corrConfig.numCorrInv = 0x2; //!< \brief Number of subsequent correlation tops with maximum <code>corrPeriod</code> RAT ticks between them
//!< needed to go from Idle to Invalid
EasyLink_cmdPropCs.csConf.busyOp = 0x1; // End carrier sense on channel Busy
EasyLink_cmdPropCs.csConf.idleOp = 0x0; // Continue carrier sense on channel Idle
EasyLink_cmdPropCs.csEndTrigger.triggerType = TRIG_REL_START; // Ends at a time relative to the command started
EasyLink_cmdPropCs.csEndTime = EasyLink_us_To_RadioTime(EASYLINK_CHANNEL_IDLE_TIME_US);
Nick
