Other Parts Discussed in Thread: CC1352R
my terminal displays a security error when I try to join my sensor to the network
Please can you describe your setup. And when you mention that other sensors work well, do you mean the same software is working on other CC1352R devices?
Please can you try using the version 5_40 of the SDK, and let us know if you see the same issue. Since it is seen only in one device, it is hard to reproduce here. It is worth checking the previous version of the SDK.
Sid
