Hi Experts,
A customer has been trying to make an application on the CC1110 chip but something is not working as intended.
They are trying to implement the power mode 2 for the device with a sleep timer. they use a code from the examples provided by TI and, for some reason, the device stays idle after the sleep timer interrupt triggers.
The program ends after leaving the interrupt and, by checking the registers, the IDLE bit is always active ('1')
I searched in the forums about this, but unfortunately, I was unable to find a solution.
Can you help? Thank you in advance
Marvin
