Hi team,
Here's the request from the customer:
During production, when writing FLASH, the debugger program is wrong without checking, which causing write data beyond FLASH address (write beyond 0x0001FFFF address). As a result, the chip can no longer be burned.
Does modifying the CCFG file cause the situation that the chip will be locked? Is there any way to unlock it by software?
What’s more, the CCFG file’s address is near the 0x0001FFFF address, how to modify it to other address. Customer tried to modify to another address, but the program can‘t run succeddfully.
Could you help check this case? Thanks.
Nick
