Other Parts Discussed in Thread: WI-SUN,
Dear TI Expert.
Our customer has a requirement,
They need to have 100 nodes, in the worst case, each node will upload 64 bytes per second, is this possible for Wi-sun using CC1312R7?
Hi Weli,
I contacted our Wi-Sun specialist, who will get in touch with you.
Arthur
Hi Weli,
A 100 node network is possible with the CC1312R7 device, but please can you elaborate on the use case?
Does each node need to transmit 64 bytes every second to the Border Router?
Sid
Hi Weli,
The 100 node network should be feasible, but the traffic requirements seem to be quite dense.
Sending 64 bytes from every single node for every second seems to be quite a lot for a mesh with 100 nodes, especially if it has multiple hops.
Is this a strict requirement or can the data be sent for a larger interval, for instance once every 5 seconds?
Sid
