Other Parts Discussed in Thread: CC1311R3, CC1311P3,
Hello TI,
My name is Hannan Mutahir from Vantage Robotics.
I wanted to check if CC1311P3/CC1311R3 for 359-527Mhz band it is possible to set for band with to 1.3MHz to achieve 1Mbps throughput or higher bandwidth to achieve higher throughput (2Mbps)? per spec sheet max is 200kbps
like for 861-054Mhz band per spec we can set to 1.3Mhz to achieve 1mbps tput
Also for CC1312R 359-527Mhz band it is possible to set for band with to 2.2MHz to achieve 1Mbps throughput as in 861-1054Mhz band?
