LP-CC2652PSIP: CC1312P SIPX
Part Number: LP-CC2652PSIP
Hello
The question herein is attributed more to the chip on this board (CC1312P SIPX) rather than the board itself (unfortunately, the component itself could not be found within the available component options)
The wireless MCU is incorporated in a board of ours. The SW utilizes SDK  7_10_00_63_eng.
The application run on board is composed of bootloader and application portions.
The entire system undergoes stress testing where we hang the application deliberately every 60 seconds thereby causing a watchdog trigger that should reset the board.
Nevertheless, stress testing revealed that every two to three days of constant running in the manner described above - the system does not recover.
Further analysis showed that the watchdog did trigger, and a reset was applied. However, the bootloader does not initiate, and the SW persists hanging.
Please be so kind to advise:
1) In your opinion what could be the cause of such a hang?
