Other Parts Discussed in Thread: CC1352P7, UNIFLASH, WI-SUN
I was trying to do OAD on CC1352P7-1 Dev kit. I did:
1. Programed dev kit with bim_offchip_LP_CC1352P7_1_nortos_ticlang.hex and ns_coap_oad_offchip_src_LP_CC1352P7_1_tirtos7_ticlang.bin simultaneously with uniflash
2. Then Programmed dev kit with ns_coap_oad_offchip_src_LP_CC1352P7_1_tirtos7_ticlang.hex
3. After getting connected with Border Router
i executed command
startoad 2020:abcd::212:4b00:2853:2fe8 CC1352P7 64 ns_coap_node_src_LP_CC1352P7_1_tirtos7_ticlang.bin
I am getting following error. OAD image filesize: 341976 bytes
C:\Ranjit\Workspace\OAD-Spinel\ti-wisunfan-pyspinel\oad_log_2020-abcd--212-4b00-2853-2fe8_2023-05-30-T16-10-42.txt
Sending OAD notification request message
Logging results in C:\Ranjit\Workspace\OAD-Spinel\ti-wisunfan-pyspinel\oad_log_2020-abcd--212-4b00-2853-2fe8_2023-05-30-T16-10-42.txt
spinel-cli >
CoAP packet received from 2020:abcd::212:4b00:2853:2fe8: type: 2 (Acknowledgement), token: 9369953346641921073, code: 2.04 (Changed), msg_id: 0
OAD notification response received
OAD upgrade rejected
please let me know with the steps, If I am doing in wrong way.
