Other Parts Discussed in Thread: CC1101, CC1310, CC1311R3, CC1312R
From what I see the CC1125 will not operate at approx 350MHz. Can you recommend a similar part that will allow Manchester coding at 350MHz.
many thanks
Rob
Hi Rob,
Have you looked at the CC1101 for your application?
The CC1101 supports 300-348 MHz and 387-464 MHz, along with Manchester encoding - Section 16 of the CC1101 Datasheet: https://www.ti.com/lit/swrs061 discusses the possible modulation formats so you can check if it is suitable for your design.
Zack
Looking through our product range, the CC13x0 and CC13x2 devices do cover this frequency range (just):
CC1312R Datasheet: https://www.ti.com/lit/swrs210 - Section 8.9
However, there has been limited testing for this frequency band and you may have to both adjust the PHY settings and tune the output matching network of the reference design if the performance isn't what you need it to be.
For more information:
There is more limited support for Manchester encoding on the CC13xx devices so I would advise checking the device/SDK documentation. Within the relevant SDK documentation on https://dev.ti.com/tirex (the CC13x0 devices have a separate SDK to the other devices), go to Documents -> Proprietary RF -> Proprietary RF User's Guide
and search for Manchester encoding:
Other documentation to check is:
SWCU117 (CC13x0, CC26x0 SimpleLink Wireless MCU Technical Reference Manual): https://www.ti.com/lit/swcu117
SWCU185 (CC13x2, CC26x2 SimpleLink Wireless MCU Technical Reference Manual): https://www.ti.com/lit/swcu185
Zack
