Other Parts Discussed in Thread: CC1354P10, , CC1352R, CC1352P, CC1352P7, CC1310
Hi there,
We have our custom design based on CC1354P10 (RGZ) with SubGHz lines + Balun (discrete) + SAW + CC1190.
- I would like to know the PA table configuration for the same.
- And does above PA table configuration will change if we use (Johnson/Murata balun which is verified for CC1352R & CC1352P versions), we hope that Johnson/murata balun can work fine with CC1354P10 RGZ (7x7mm) as well, as we thinks that it is pin to pin compatible with CC1352P7
- And this PA table configuration remains same for any modulation/radio that CC1354P10 supports? (ex. WiSUN with different phy mode, TI 15.4 stack etc), or it is required to have tuning based on the phy/mode we select?
- Ideally to achieve 27dBm output, what maximum power we should use from CC1354P10 ? (SubGHZ lines)
- And any thought, like how we can make the dedicated TX (27dBm) and dedicated RX with any of above configuration?
- Is there any way to measure the output power (conductive) in our board using RF Studio? (otherwise we planned for the lab testing with spectrum & power analyzer but before that i would like to know if is there any way to check that without standard instruments?)
The Mat
