I need functional safety FIT rate for CC1314R106T0RSK, TPS7A0225PDBVR and TXU0304PWRQ1.
Karishma
Karishma
If you go to "order and quality" for the chip you are interested in, then click on the link under "Quality, reliability & packaging information"
Thanks for the response, however I didn't find any data there related to Functional Safety FIT (Base Failure Rate) Estimates per IEC 62380 and SN 29500.
Above failure rates are summarized by technology and mapped to the associated material part numbers. It's often derived from reliability testing, such as High Temperature Operating Life (HTOL) and Early Life Failure Rate (ELFR) testing.
I am interested in Component Base Failure Rates (BFR) per Siemens Norm SN 29500-2, which are then used to derive functional FIT rates, taking into account various factors like temperature, voltage, and operating conditions.
I hope this clears up the query.
Hi Karishma,
thank you very much for the clarification.
I will check internally for the Component Base Failure Rates (BFR) per Siemens Norm SN 29500-2 and come back to you as soon as possible.
Kind regards,
Theo
Hi Karishma,
I reached out to you by mail.
please let us continue the discussion there so that we can help you find a suitable solution.
Kind regards,
Theo
