Hi, can someone help me , steps to configure the clock speed 4 MHz in CC1310 , i am using CCS IDE
As already said, the CM3 only supports running at 48MHz. It's worth just mentioning though that the Sensor Controller Engine (SCE) will always execute code at 24 MHz.
If you're trying to implement a low power application, you should look into the SCE. It can perform a lot of tasks at a fraction of the power consumption of the CM3 in a lot of use-cases.
Niklas
