Other Parts Discussed in Thread: CC1310
- Any document can introduce SmartRF Studio 7 index meaning, like “RX Filter BW”, “Symbol Rate”, "Whitening" and “Deviation” ? Any relationship between them?
- How can I know which TX bandwidth that I use now? Does it have relationship with question 1 index?
- TX power value (dBm) means output from IC pin or antenna connector?
- If I want to adjust the relationship between "TX power value (dBm)" and "txPower hex value ( in customize)", have document to explain what the hex step will increase/decrease TX power?
- RSSI value is equal to RX sensitivity?
Thank you.
