LAUNCHXL-CC1312R1: I2C_Transfer( ) function call cause system halt
Part Number: LAUNCHXL-CC1312R1
Other Parts Discussed in Thread: CC1312R
- CCS version : 10.1.0.00010
- SDK : SimpleLink CC13X2 SDK 4.20.00.35
- Example Source : CC1312R LaunchPad / TI 15.4-Stack / sensor
Whole source code attached in this post.
When I call I2C_Transfer( ), whole system halted with "Main_assertHandler:assertReason = 4"
which observed by Debug session.
sensor_CC1312R1_LAUNCHXL_tirtos_ccs.zip
Most of code changes are done to Main.c
Could you check my code and explain why this is happening?
Jay
  • Jay,
    in ti_drivers_config.h you set the I2C max bitrate to 100kHz
    /* max speed unspecified, defaulting to 100 Kbps */
    #define CONFIG_I2C_GYRO_MAXSPEED   (100U) /* Kbps */
    #define CONFIG_I2C_GYRO_MAXBITRATE ((I2C_BitRate)I2C_100kHz)
    but in main.c you set the i2cParams.bitrate to 400kHz
        I2C_init();
        I2C_Params_init(&i2cParams);
        i2cParams.bitRate = I2C_400kHz;
        i2cParams.transferMode = I2C_MODE_BLOCKING;
    Can you try to align the I2C bit rate and try again?
    Daniel
  • Hellio Daniel,
    I2C_init();
    i2cParams.bitRate = I2C_100kHz;
    Modify Main.c but result is same.
    Jay
  • Jay,
    Sorry I missed this the first time I looked at your code. The issue is you are calling the i2c_transfer() functions before you call bios_start().
    All TI Driver functions need to be called after you call bios_start() since they rely on hwi, swi, and systick. You are getting hwi asserts because you haven't enabled hardware interrupts yet.
    Daniel
  • Hello, Daniel
    Thanks a lot. I had moved my I2C codes to custom made task and system now seems working.
    - I2C initialize : successful.
    - I2C transfer(TX) : I still got I2C transaction failed message but anyway I can observe I2C TX signal by oscilloscope
    if(I2C_transfer(i2c, &i2cTransaction)) {
       Display_printf(display, 0, 0, "I2C transaction success");
    else {
       Display_printf(display, 0, 0, "I2C transaction failed"); // ???
    Jay
