I have a question about the manual power-on sequence on page 37 of the CC113L data sheet.
The first action is described as "Set SCLK = 1 and SI = 0".
Is there any disadvantage to setting SCLK = 0 at this time?
In the UsersGuide it's listed a couple of options to reset the part with power-up. Any reason you want to do the manual initial reset and not trust the POR described in the chapter before?
I have not tried this function but since it's written that the SCLK = 1 I assume that this is a requirement. If not the line had just said "SI = 0".
Hi TER,
Successful execution of automatic POR depends on the power lamp up and off times in Section 4.10. Therefore, I thought it would be better to use the manual reset performed by manual power-up sequence to ensure chip reset.
Sinsan
