Other Parts Discussed in Thread: CC1310, CC1190
I am exploring the possibility to use a customized board based on CC1310 + CC1390 as a CC1310 standalone board. What will happen in terms of TX/RX signal strength and power consumption in the following two scenarios:
a) RANGE_EXT_MODE is simply not enabled in collector/sensor example code, as a result PA_EN, LNA_EN, HGM pins on CC1390 will be floating.
b) PA_EN and LNA_EN pins on CC1390 are explicitly set to 0 and therefore CC1390 is essentially disabled. In this case, will CC1390 will simply let TX and RX signal pass through and not consume power?
Please advise. Thanks in advance.
