If transceiver is supposed to receive data form sources that have slightly different link rates, The User's Guide recommends to adjust TOC_LIMIT field in the TOC_CFG register (page 98).
It is not clear what threshold should be used for the settings 01 and 11. Why units for thresholds are in % ppm? What are the thresholds in Hz for the link rate e.g. 200kHz ? Do you have any recommendations for the selection of TOC_PRE_SYNC_BLOCKEN and TOC_POST_SYNC_BLOCKEN when TOC_LIMIT is not 0?
Alex
