Other Parts Discussed in Thread: CC2650, CC1310
I am working on a project for the Hackaday Prize 2017, you can see it here
Right now i am using CC2650, but for the final prototype i will use CC1350.
I have gone through almost all the questions and answers regarding antenna and balun for CC1350 and CC1310. However they are scattered and sometimes inconclusive.
Since right now CC1350 modules are not available, I am forced to make my own design from scratch. But because of size restrictions, I would want to use external chip antennas. Also I would like to use baluns instead of discrete passives.
Also I am under a deadline for a proof of concept so I want to make “single ended design” like in CC1350 Sensor Tag Kit for simplicity.
Right now what I have to do is (according to my understanding) the following –
1. Select any 2.4GHz antenna that has 50 ohm impedance.
2. Select any SubGHz antenna that has 50 ohm impedance.
3. Get a balun for CC1350…..unfortunately its not available. So I do the following –
According to some suggestions for questions, one was to use the CC1310 SubGHz balun for SubGHz antenna for CC1350 and the CC2650 balun for 2.4GHz antenna for CC1350.
Q1) Is it a good idea to do this or are there dedicated baluns for CC1350 (preferably, currently available for purchase)?
According to TI App Note for IPC for CC1310 http://www.ti.com/lit/an/swra524a/swra524a.pdf
The SubGHz balun for CC1310 from Johanson Tech is https://www.johansontechnology.com/datasheets/chipset-specific/0850BM14E0016.pdf
The 2.4GHz CC2650 balun from Johanson Tech is https://www.johansontechnology.com/datasheets/baluns-matched/2450BM14G0011.pdf
Are there any other alternatives for the baluns or dedicated baluns for CC1350 that are currently available for purchase?
Q2) Are there tested(recommended) antennas for CC1350 too because since the modules will come in “end of 2017” , they will be using chip antennas as far as I can tell, and I am guessing that TI engineers must have already tested some antennas by now.
