Hello E2E folks,
I'm using a modified version of Toby Jaffey's small bootloader in order to be able to remotely upgrade firmware.
The problem I'm having is that after I jump to my user code at offset 0x800, none of my ISRs are being called. I tested this code running at offset 0 instead of 0x800 and the ISRs run.
Before jumping to user code I'm clearing all interrupt flags and disabling interrupts. I reenable them in the init portion of my main function. Also I'm compiling my code for an offset of 0x800 using the sdcc compiler.
Has anyone encountered this problem?
Lee
