CC1310: AES Encryption and Decryption
Part Number: CC1310
I want the RF packets to be encrypted before transmission and to be decrypted at receiver side. I have searched  the cc1310 SDK for AES sample example but there was not any to begin with. The driver library does provide some stuff but that is CC26XX related... from which example should I start with ?'
Could anyone share insight on how AES works and what it basically needs?
  • Hello Prachi,
    For AES software please ref to this
    You can integrate AES into your CC1310 project.
    Prashanth
  • First, you should figure out which AES mode you want to use and how to do the key exchange etc. Crypto is a complicated field and care should be used when implementing it to avoid creating security weaknesses.
    The crypto module on CC26xx and CC13xx is the same, hence dev.ti.com/.../_crypto_c_c26_x_x_8h.html is also valid for CC13xx.
    The E2E post below shows how CCM can be implemented:
    e2e.ti.com/.../641353
    Note the code examples are meant to show how to use some if the AES modes, it's not a system solution.
  • Hello TER,
    Thanks a lot for your reply!
    I want to use CCM method of encryption and want to transmit the encrypted packet and decrypt it on other end, so modified example of ECB method built by you and modified it for CCM.
    In one code only if I do encryption and decryption by CCM  it works perfectly code attached below. But now I want the encrypted  part to be copied in to RF packet  before transmission and to be decrypted in another code when received as RF packet.  This part is little difficult to understand for me...how the key is shared and how to extract the header and other things like noncelength,aadlength etc. Though I have built two separate code for that I think I was unable to decrypt it properly...I think I've to understand many things here. I have attached codes and would like to request you to have review of the code and please me guide on above things.
    Prachi Patil
     * Copyright (c) 2015-2016, Texas Instruments Incorporated
     * All rights reserved.
     * Redistribution and use in source and binary forms, with or without
     * modification, are permitted provided that the following conditions
     * are met:
     * *  Redistributions of source code must retain the above copyright
     * *  Redistributions in binary form must reproduce the above copyright
     *    documentation and/or other materials provided with the distribution.
     * *  Neither the name of Texas Instruments Incorporated nor the names of
     * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
     * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
     * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
     * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
     * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
     * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
     * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
     * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
     * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
     * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
     * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    /***** Includes *****/
    #include <stdlib.h>
    #include <xdc/std.h>
    #include <xdc/runtime/System.h>
    #include <ti/sysbios/BIOS.h>
    #include <ti/sysbios/knl/Task.h>
    /* Drivers */
    #include <ti/drivers/rf/RF.h>
    #include <ti/drivers/PIN.h>
    #include <ti/drivers/crypto/CryptoCC26XX.h>
    /* Board Header files */
    #include "Board.h"
    #include "smartrf_settings/smartrf_settings.h"
    /* Pin driver handle */
    static PIN_Handle ledPinHandle;
    static PIN_State ledPinState;
     * Application LED pin configuration table:
     *   - All LEDs board LEDs are off.
    PIN_Config pinTable[] =
     Board_RLED | PIN_GPIO_OUTPUT_EN | PIN_GPIO_LOW | PIN_PUSHPULL | PIN_DRVSTR_MAX,
     PIN_TERMINATE
    /***** Defines *****/
    #define TX_TASK_STACK_SIZE 1024
    #define TX_TASK_PRIORITY   2
    /* Packet TX Configuration */
    #define PAYLOAD_LENGTH      24
    #define PACKET_INTERVAL     (uint32_t)(4000000*0.5f) /* Set packet interval to 500ms */
    #define macLength           (4)
    #define clearTextLength     (16)
    #define cipherTextLength    (macLength + clearTextLength)
    #define nonceLength         (12)
    #define aadLength           (14)
    /***** Prototypes *****/
    static void txTaskFunction(UArg arg0, UArg arg1);
    static void encryptPacketCCM(uint8_t *key);
    /***** Variable declarations *****/
    static Task_Params txTaskParams;
    Task_Struct txTask;    /* not static so you can see in ROV */
    static uint8_t txTaskStack[TX_TASK_STACK_SIZE];
    static RF_Object rfObject;
    static RF_Handle rfHandle;
    uint32_t curtime;
    static uint8_t rawPacket[PAYLOAD_LENGTH];
    // Allocate enough space for encrypted packet
    static uint8_t packet[PAYLOAD_LENGTH + AES_ECB_LENGTH];
    // Key variables
    //static CryptoCC26XX_KeyLocation keyLocation = CRYPTOCC26XX_KEY_0;
    //static uint8_t cryptoKey[16] = { 0x2B, 0x7E, 0x15, 0x16, 0x28, 0xAE, 0xD2, 0xA6,
    //                    0xAB, 0xF7, 0x15, 0x88, 0x09, 0xCF, 0x4F, 0x3C };
    // Holds the AES-CCM setup for this example
    typedef struct
        uint8_t key[16];                                // A 128 Bit AES key
        CryptoCC26XX_KeyLocation keyLocation;           // One of 8 key locations in the hardware
        uint8_t clearAndCipherText[cipherTextLength];   // Holds the cleartext before, and the ciphertext
        // after the encryption operation.
        // Ciphertext = encrypted text + message authentication code (MAC).
        uint8_t nonce[nonceLength];                     // A value that is used only once (cryptographic term 'nonce')
        uint8_t header[aadLength];                      // A header that is not encrypted but is authenticated in the operation (AAD).
        uint8_t verificationMAC[macLength];             // Location that the recalculated and encrypted MAC is stored during decryption.
    } AesCcmExample;
    AesCcmExample ccmSetup =
     .key = { 0x2B, 0x7E, 0x15, 0x16, 0x28, 0xAE, 0xD2, 0xA6,
              0xAB, 0xF7, 0x15, 0x88, 0x09, 0xCF, 0x4F, 0x3C },
              .keyLocation = CRYPTOCC26XX_KEY_0,
              .clearAndCipherText = { 't','h','i','s','i','s','a','p','l','a','i','n','t','e','x','t','0','0','0','0' },
              .nonce  = { 't','h','i','s','i','s','a','n','o','n','c','e' },
              .header = { 't','h','i','s','i','s','a','h','e','a','d','e','r','1' }
    //static uint16_t seqNumber;
    static PIN_Handle pinHandle;
    void encryptPacketCCM(uint8_t * key)
        uint8_t clearTextBuffer[AES_ECB_LENGTH];
        CryptoCC26XX_Handle             handle;
        int32_t                         keyIndex;
        int32_t                         status;
        CryptoCC26XX_AESCCM_Transaction trans;
        // Initialize Crypto driver
        CryptoCC26XX_init();
        // Open the crypto hardware with non-exclusive access and default parameters
        // Attempt to open CryptoCC26XX.
        handle = CryptoCC26XX_open(Board_CRYPTO, false, NULL);
        if (!handle) {
            System_abort("Crypto module could not be opened.");
        // Allocate a key storage location in the hardware
        keyIndex = CryptoCC26XX_allocateKey(handle, ccmSetup.keyLocation, (const uint32_t *) ccmSetup.key);
        //keyIndex = CryptoCC26XX_allocateKey(handle, ecbExample.keyLocation,
        //(const uint32_t *) ecbExample.key);
        // keyIndex = CryptoCC26XX_allocateKey(handle, keyLocation, (const uint32_t *) key);
        if (keyIndex == CRYPTOCC26XX_STATUS_ERROR) {
            System_abort("Key Location was not allocated.");
        // Encrypt and authenticate the message
        CryptoCC26XX_Transac_init((CryptoCC26XX_Transaction *) &trans, CRYPTOCC26XX_OP_AES_CCM_ENCRYPT);    /// only change is CRYPTOCC26XX_OP_AES_CCM
        // Setup transaction
        trans.keyIndex         = keyIndex;
        trans.authLength = macLength;
        trans.nonce  = (char *) ccmSetup.nonce;
        trans.header = (char *) ccmSetup.header;
        trans.fieldLength  = 3;
        trans.msgInLength  = clearTextLength;
        trans.headerLength = aadLength;
        trans.msgIn  = (char *) &(ccmSetup.clearAndCipherText[0]);                // Message is encrypted in place
        trans.msgOut = (char *) &(ccmSetup.clearAndCipherText[clearTextLength]);  // MAC will be written to this position
        status = CryptoCC26XX_transact(handle, (CryptoCC26XX_Transaction *) &trans);
        if(status != CRYPTOCC26XX_STATUS_SUCCESS){
            System_abort("Encryption and signing failed.");
        // Decrypt the cipher text and authenticate the message
        // Initialize transaction
        CryptoCC26XX_Transac_init((CryptoCC26XX_Transaction *) &trans, CRYPTOCC26XX_OP_AES_CCM_DECRYPT);  /// only change is CRYPTOCC26XX_OP_AES_CCMINV
        trans.msgInLength  = cipherTextLength;
        trans.msgIn  = (char *) &(ccmSetup.clearAndCipherText[0]);                // Message is decrypted in place
        trans.msgOut = (char *) &(ccmSetup.clearAndCipherText[clearTextLength]);  // Points to the MAC, is used as input here
      // trans.msgOut = (char *) ccmSetup.verificationMAC;
        //  memset(&(ccmSetup.clearAndCipherText[clearTextLength]), 0x0, clearTextLength);   // added this part from ecb example
        // Do AES-CCM Decryption and authentication
            System_abort("Decryption and authentication failed.");
        // Release the key location
        status = CryptoCC26XX_releaseKey(handle, &keyIndex);
        if (status != CRYPTOCC26XX_STATUS_SUCCESS) {
            System_abort("Key release was not successful.");
        CryptoCC26XX_close(handle);
    /***** Function definitions *****/
    void TxTask_init(PIN_Handle inPinHandle)
        pinHandle = inPinHandle;
        Task_Params_init(&txTaskParams);
        txTaskParams.stackSize = TX_TASK_STACK_SIZE;
        txTaskParams.priority = TX_TASK_PRIORITY;
        txTaskParams.stack = &txTaskStack;
        txTaskParams.arg0 = (UInt)1000000;
        Task_construct(&txTask, txTaskFunction, &txTaskParams, NULL);
        uint32_t curtime;
        RF_Params rfParams;
        RF_Params_init(&rfParams);
        RF_cmdPropTx.pktLen = (PAYLOAD_LENGTH / AES_ECB_LENGTH + 1)*AES_ECB_LENGTH;
        //RF_cmdPropTx.pktLen = PAYLOAD_LENGTH;
        RF_cmdPropTx.pPkt = packet;
        RF_cmdPropTx.startTrigger.triggerType = TRIG_NOW;
        RF_cmdPropTx.startTrigger.pastTrig = 1;
        RF_cmdPropTx.startTime = 0;
        /* Request access to the radio */
        rfHandle = RF_open(&rfObject, &RF_prop, (RF_RadioSetup*)&RF_cmdPropRadioDivSetup, &rfParams);
        /* Set the frequency */
        RF_postCmd(rfHandle, (RF_Op*)&RF_cmdFs, RF_PriorityNormal, NULL, 0);
        /* Get current time */
        curtime = RF_getCurrentTime();
        while(1)
            encryptPacketCCM(ccmSetup.key);
            //decryptPacketECB(cryptoKey);
            curtime += PACKET_INTERVAL;
            RF_cmdPropTx.startTime = curtime;
            /* Send packet */
            RF_EventMask result = RF_runCmd(rfHandle, (RF_Op*)&RF_cmdPropTx, RF_PriorityNormal, NULL, 0);
            if (!(result & RF_EventLastCmdDone))
                /* Error */
                while(1);
            //        RF_yield(rfHandle);
            PIN_setOutputValue(pinHandle, Board_RLED,!PIN_getOutputValue(Board_RLED));
            Task_sleep(5000000/Clock_tickPeriod);
     *  ======== main ========
    int main(void)
        /* Call driver init functions. */
        Board_initGeneral();
        /* Open LED pins */
        ledPinHandle = PIN_open(&ledPinState, pinTable);
        if(!ledPinHandle)
            System_abort("Error initializing board LED pins\n");
        /* Initialize task */
        TxTask_init(ledPinHandle);
        /* Start BIOS */
        BIOS_start();
        return (0);
     * are met:
    #include <stdlib.h>
    /* Drivers */
    #include "Board.h"
        PIN_TERMINATE
    #define PAYLOAD_LENGTH      46
    //atic void encryptPacketECB(uint8_t *key);
    uint32_t curtime;
    // Key variables
    typedef struct
    } AesCcmExample;
            int32_t                         keyIndex;
            int32_t                         status;
            if (!handle) {
           memcpy(packet,trans.header,aadLength);
           memcpy(&packet[aadLength],trans.nonce,nonceLength);
           memcpy(&packet[aadLength+nonceLength],ccmSetup.clearAndCipherText[clearTextLength],cipherTextLength);
        uint32_t curtime;
        RF_Params rfParams;
        RF_cmdPropTx.pktLen = (PAYLOAD_LENGTH / AES_ECB_LENGTH + 1)*AES_ECB_LENGTH;   /// to do- check  length with
        while(1)
            /* Send packet */
                /* Error */
                while(1);
    int main(void)
        /* Open LED pins */
        if(!ledPinHandle)
        /* Start BIOS */
        BIOS_start();
        return (0);
     * are met:
    #include <stdlib.h>
    #include <xdc/cfg/global.h>
    #include <ti/sysbios/knl/Semaphore.h>
    /* Drivers */
    #include "driverlib/rf_prop_mailbox.h"
    #include "Board.h"
    #include "RFQueue.h"
    #include <stdlib.h>
     Board_GLED | PIN_GPIO_OUTPUT_EN | PIN_GPIO_LOW | PIN_PUSHPULL | PIN_DRVSTR_MAX,
        PIN_TERMINATE
    #define RX_TASK_STACK_SIZE 1024
    #define RX_TASK_PRIORITY   2
    /* Packet RX Configuration */
    #define DATA_ENTRY_HEADER_SIZE 8  /* Constant header size of a Generic Data Entry */
    #define MAX_LENGTH             100 /* Max length byte the radio will accept */
    #define NUM_DATA_ENTRIES       2  /* NOTE: Only two data entries supported at the moment */
    #define NUM_APPENDED_BYTES     2  /* The Data Entries data field will contain:
                                       * 1 Header byte (RF_cmdPropRx.rxConf.bIncludeHdr = 0x1)
                                       * Max 30 payload bytes
                                       * 1 status byte (RF_cmdPropRx.rxConf.bAppendStatus = 0x1) */
    static void rxTaskFunction(UArg arg0, UArg arg1);
    static void callback(RF_Handle h, RF_CmdHandle ch, RF_EventMask e);
    static void decryptPacketCCM(uint8_t *key);
    static Task_Params rxTaskParams;
    Task_Struct rxTask;    /* not static so you can see in ROV */
    static uint8_t rxTaskStack[RX_TASK_STACK_SIZE];
    /* Buffer which contains all Data Entries for receiving data.
     * Pragmas are needed to make sure this buffer is 4 byte aligned (requirement from the RF Core) */
    #if defined(__TI_COMPILER_VERSION__)
        #pragma DATA_ALIGN (rxDataEntryBuffer, 4);
            static uint8_t rxDataEntryBuffer[RF_QUEUE_DATA_ENTRY_BUFFER_SIZE(NUM_DATA_ENTRIES,
        MAX_LENGTH,
        NUM_APPENDED_BYTES)];
    #elif defined(__IAR_SYSTEMS_ICC__)
        #pragma data_alignment = 4
        MAX_LENGTH,
    #elif defined(__GNUC__)
            static uint8_t rxDataEntryBuffer [RF_QUEUE_DATA_ENTRY_BUFFER_SIZE(NUM_DATA_ENTRIES,
                MAX_LENGTH, NUM_APPENDED_BYTES)] __attribute__ ((aligned (4)));
    #else
        #error This compiler is not supported.
    #endif
    /* Receive dataQueue for RF Core to fill in data */
    static dataQueue_t dataQueue;
    static rfc_dataEntryGeneral_t* currentDataEntry;
    static uint8_t packetLength;
    static uint8_t* packetDataPointer;
    static uint8_t packet[MAX_LENGTH + NUM_APPENDED_BYTES - 1]; /* The length byte is stored in a separate variable */
    static uint8_t decryptPacket[MAX_LENGTH + NUM_APPENDED_BYTES - 1];
    // Key variables
    uint8_t header[14];
    uint8_t macBuffer[40];
    typedef struct
    } AesCcmExample;
              .clearAndCipherText = { 'l','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0' },
    //semaphore object definitions
    Semaphore_Struct semStruct;
    Semaphore_Handle semHandle;
    void decryptPacketCCM(uint8_t * key)
          memcpy(header,packet,aadLength);
            int32_t                         keyIndex;
            int32_t                         status;
            if (!handle) {
                trans.msgIn  = (char *) &(packet[aadLength+nonceLength]);                // Message is decrypted in place
                trans.msgOut = (char *) macBuffer;  // Points to the MAC, is used as input here
    void RxTask_init(PIN_Handle ledPinHandle) {
        pinHandle = ledPinHandle;
        Task_Params_init(&rxTaskParams);
        rxTaskParams.stackSize = RX_TASK_STACK_SIZE;
        rxTaskParams.priority = RX_TASK_PRIORITY;
        rxTaskParams.stack = &rxTaskStack;
        rxTaskParams.arg0 = (UInt)1000000;
        Task_construct(&rxTask, rxTaskFunction, &rxTaskParams, NULL);
        // Radio defs
        RF_Params rfParams;
        if( RFQueue_defineQueue(&dataQueue,
                                rxDataEntryBuffer,
                                sizeof(rxDataEntryBuffer),
                                NUM_DATA_ENTRIES,
                                MAX_LENGTH + NUM_APPENDED_BYTES))
            /* Failed to allocate space for all data entries */
            while(1);
        /* Modify CMD_PROP_RX command for application needs */
        RF_cmdPropRx.pQueue = &dataQueue;           /* Set the Data Entity queue for received data */
        RF_cmdPropRx.rxConf.bAutoFlushIgnored = 1;  /* Discard ignored packets from Rx queue */
        RF_cmdPropRx.rxConf.bAutoFlushCrcErr = 1;   /* Discard packets with CRC error from Rx queue */
        RF_cmdPropRx.maxPktLen = MAX_LENGTH;        /* Implement packet length filtering to avoid PROP_ERROR_RXBUF */
        RF_cmdPropRx.pktConf.bRepeatOk = 1;
        RF_cmdPropRx.pktConf.bRepeatNok = 1;
        /* Enter RX mode and stay forever in RX */
        RF_postCmd(rfHandle, (RF_Op*)&RF_cmdPropRx, RF_PriorityNormal, &callback, IRQ_RX_ENTRY_DONE);
        while(1) {
            Semaphore_pend(semHandle, BIOS_WAIT_FOREVER);
            decryptPacketCCM(ccmSetup.key);
            PIN_setOutputValue(pinHandle, Board_RLED ,!PIN_getOutputValue(Board_RLED));
        if (e & RF_EventRxEntryDone)
            /* Toggle pin to indicate RX */
            PIN_setOutputValue(pinHandle, Board_GLED,!PIN_getOutputValue(Board_GLED));
            /* Get current unhandled data entry */
            currentDataEntry = RFQueue_getDataEntry();
            /* Handle the packet data, located at &currentDataEntry->data:
             * - Length is the first byte with the current configuration
             * - Data starts from the second byte */
            packetLength      = *(uint8_t*)(&currentDataEntry->data);
            packetDataPointer = (uint8_t*)(&currentDataEntry->data + 1);
            /* Copy the payload + the status byte to the packet variable */
            memcpy(packet, packetDataPointer, (packetLength + 1));
            RFQueue_nextEntry();
            Semaphore_post(semHandle);
    int main(void)
        Semaphore_Params semParams;
        /* Construct a Semaphore object to be use as a resource lock, inital count 1 */
        Semaphore_Params_init(&semParams);
        Semaphore_construct(&semStruct, 0, &semParams);
        /* Obtain instance handle */
        semHandle = Semaphore_handle(&semStruct);
        /* Open LED pins */
        if(!ledPinHandle)
        RxTask_init(ledPinHandle);
        /* Start BIOS */
        BIOS_start();
        return (0);
