Part Number: CC1310
i've commanded the radio to do a non-terminating receive using CMD_RX_TEST....
while that command is executing, i repeatedly call the immediate CMD_GET_RSSI to retrieve an RSSI value....
except for the very first of these calls, i do retrieve what appears to a "reasonable" RSSI value that reflects my environment (where i can control the RF noise)....
what i've noticed, however, is that all subsequent calls show *exactly* the values -- despite the fact that i add/remove jammers mid-stream....
does this initial RSSI value somehow "latch" as part of the CMD_RX_TEST command???
if i want to sample the air for (say) 5 seconds, do i need to issue CMD_RX_TEST repeatedly???
thanks, bob.
