Other Parts Discussed in Thread: TMP116, SYSBIOS, TMP007, CC1310
I have a problem with the RF communication using the CC1310F64 4x4mm type chip with 3v, this chip interfaced with a , the code developed and loaded on this chip works with the sensor (Presence of the SDA and SCL signal) but the emmision RF does not work, for the reception I use Smart RFstudio 7 - see attached the code n ° 1.
Before inserting the i2c parmetres and the TMP 116, the RF is working properly and sending data- see the attached code # 2.
Thank you in advance for your help.
/* * Copyright (c) 2015-2016, Texas Instruments Incorporated * All rights reserved. * * Redistribution and use in source and binary forms, with or without * modification, are permitted provided that the following conditions * are met: * * * Redistributions of source code must retain the above copyright * notice, this list of conditions and the following disclaimer. * * * Redistributions in binary form must reproduce the above copyright * notice, this list of conditions and the following disclaimer in the * documentation and/or other materials provided with the distribution. * * * Neither the name of Texas Instruments Incorporated nor the names of * its contributors may be used to endorse or promote products derived * from this software without specific prior written permission. * * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */ /* * ======== rfEasyLinkTx.c ======== */ /* XDCtools Header files */ #include <stdlib.h> #include <xdc/std.h> #include <xdc/runtime/System.h> #include <xdc/runtime/Error.h> #include <semaphore.h> /* BIOS Header files */ #include <ti/drivers/rf/RF.h> #include <ti/sysbios/BIOS.h> #include <ti/sysbios/knl/Task.h> #include <ti/sysbios/knl/Clock.h> #include <ti/drivers/GPIO.h> #include <ti/drivers/I2C.h> /* TI-RTOS Header files */ #include <ti/drivers/PIN.h> #include <ti/drivers/Power.h> #include <ti/devices/cc13x0/driverlib/aon_batmon.h> #include <ti/devices/cc13x0/driverlib/aux_adc.h> #include <ti/devices/cc13x0/driverlib/chipinfo.h> #include <ti/devices/cc13x0/driverlib/sys_ctrl.h> #include <semaphore.h> #include <ti/sail/tmp116/tmp116.h> /* Board Header files */ #include "Board.h" /* EasyLink API Header files */ #include "easylink/EasyLink.h" #include "sc/scif.h" #include "version.h" #include "../sonde_gw_fw/sys_intf.h" #include <string.h> #include <math.h> #define RFEASYLINKTX_TASK_STACK_SIZE 1024 #define RFEASYLINKTX_TASK_PRIORITY 2 #define RFEASYLINKTX_BURST_SIZE 1 Task_Struct txTask; /* not static so you can see in ROV */ static Task_Params txTaskParams; static uint8_t txTaskStack[RFEASYLINKTX_TASK_STACK_SIZE]; Task_Struct sensorTask; /* not static so you can see in ROV */ static Task_Params sensorTaskParams; static uint8_t sensorTaskStack[RFEASYLINKTX_TASK_STACK_SIZE]; TMP116_Handle tmp116Handle ; I2C_Handle AppI2cHandle ; I2C_Transaction i2cTransaction; I2C_Params AppI2cParams; TMP116_Params tmp116Params; sem_t tmp116Sem; float temp; static PIN_State pinState; static PIN_Handle pin_handle; typedef struct { uint8_t reason; int16_t temp_deg_frac_8; uint8_t bat_20mV; } opto_sonde_data_t; //const int OPTOSONDE_BROKEN_TEMP_SENSOR_THRESHOLD = 1500 * 1000; // 1.5 V //#define OPTOSONDE_DEMO_MODE 1 PIN_Config pinTable[] = { PIN_ID(8) | PIN_INPUT_EN | PIN_PULLUP | PIN_HYSTERESIS, PIN_TERMINATE }; void sleepAndReset(uint32_t sleep_time_secs) { // Enable button interrupt wake up PIN_setInterrupt(pin_handle, PIN_ID(8) | PIN_IRQ_NEGEDGE); uint32_t secs = sleep_time_secs; while (secs > 0) { uint32_t sleep_s = secs > 2000 ? 2000 : secs; Task_sleep((sleep_s * 1000u * 1000) / Clock_tickPeriod); secs -= sleep_s; } SysCtrlSystemReset(); } void *tmp116AlertTask(void *arg0) { uint16_t data; while(1) { /* Pend on semaphore, tmp116Sem */ if (0 == sem_wait(&tmp116Sem)) { /* Reads status register, resetting the ALERT pin */ TMP116_readStatus(tmp116Handle, &data); } } } static void rfEasyLinkTxFnx(UArg arg0, UArg arg1) { opto_sonde_data_t* optosonde_data = (opto_sonde_data_t*) arg0; // rtc_cmd_t* rtc_cmd = arg1; // EasyLink_init(EasyLink_Phy_625bpsLrm); // EasyLink_init(EasyLink_Phy_5kbpsSlLr); EasyLink_init(EasyLink_Phy_Custom); /* * If you wish to use a frequency other than the default, use * the following API: * EasyLink_setFrequency(868000000); */ /* Set output power to 12dBm */ // EasyLink_setRfPwr(12); EasyLink_setRfPwr(10); EasyLink_TxPacket txPacket; // Fill packet data uint8_t payload_ptr = 0; // Payload version txPacket.payload[payload_ptr++] = (uint8_t) (0x0); // Src MAC EasyLink_getIeeeAddr(&txPacket.payload[payload_ptr]); payload_ptr += 8; // Copy data txPacket.payload[payload_ptr++] = (uint8_t) (optosonde_data->reason); txPacket.payload[payload_ptr++] = (uint8_t) (optosonde_data->temp_deg_frac_8 >> 8); txPacket.payload[payload_ptr++] = (uint8_t) (optosonde_data->temp_deg_frac_8); txPacket.payload[payload_ptr++] = (uint8_t) (optosonde_data->bat_20mV); // Firmware version memcpy(&txPacket.payload[payload_ptr], &VERSION_HASH, sizeof(VERSION_HASH)); payload_ptr += sizeof(VERSION_HASH); txPacket.len = payload_ptr; txPacket.absTime = 0; txPacket.dstAddr[0] = OPTOSONDE_ADDR; EasyLink_Status result = EasyLink_transmit(&txPacket); if (result == EasyLink_Status_Success) { /* Toggle LED1 to indicate TX */ // PIN_setOutputValue(pinHandle, Board_PIN_LED1,!PIN_getOutputValue(Board_PIN_LED1)); } else { /* Toggle LED1 and LED2 to indicate error */ // PIN_setOutputValue(pinHandle, Board_PIN_LED1,!PIN_getOutputValue(Board_PIN_LED1)); // PIN_setOutputValue(pinHandle, Board_PIN_LED2,!PIN_getOutputValue(Board_PIN_LED2)); } // Prevent button reset overload if (optosonde_data->reason == optosonde_reason_button) { Task_sleep(1000000 / Clock_tickPeriod); } // Tell RTC to sleep #ifdef OPTOSONDE_DEMO_MODE uint32_t sleep_time_s = 30; #elif OPTOSONDE_VITICODE uint32_t sleep_time_s = 10 * 60; #else uint32_t sleep_time_s = 1 * 3600; #endif sleepAndReset(sleep_time_s); } void sendorTask_AlertCB() { static opto_sonde_data_t optosonde_data; I2C_init(); TMP116_init(); /* Clear the ALERT interrupt source */ scifClearAlertIntSource(); /* Only handle the periodic event alert */ if (scifGetAlertEvents() & (1 << SCIF_ADCMEAS_TASK_ID)) { optosonde_data.reason = optosonde_reason_periodic; /* Get the SCE "output" structure */ SCIF_ADCMEAS_OUTPUT_T* pOutput = scifGetTaskStruct(SCIF_ADCMEAS_TASK_ID, SCIF_STRUCT_OUTPUT); //GPIO_init(); // GPIO_write(Board_TMP116_PWR, Board_TMP116_ON); I2C_Params_init(&AppI2cParams); AppI2cParams.transferMode = I2C_MODE_BLOCKING; AppI2cParams.transferCallbackFxn = NULL; AppI2cParams.bitRate = I2C_400kHz; AppI2cHandle = I2C_open(CC1310_LAUNCHXL_I2C0, NULL); if(AppI2cHandle == NULL){ /* Error opening I2C */ while (1); } TMP116_Params_init(&tmp116Params); /* Callback for ALERT event */ tmp116Handle = TMP116_open(Board_TMP007_ROOMTEMP, AppI2cHandle, &tmp116Params); if (tmp116Handle == NULL) { while(1); } /* Allow the sensor hardware to complete its first conversion */ TMP116_setTempLimit(tmp116Handle, TMP116_CELSIUS,(float)30.0F, (float)20.0F) ; /*int32_t adcVal_uV[5]; int i; for (i = 0; i < 4; i++) { adcVal_uV[i] = AUXADCValueToMicrovolts(AUXADC_FIXED_REF_VOLTAGE_NORMAL, AUXADCAdjustValueForGainAndOffset(pOutput->ntcraw[i], AUXADCGetAdjustmentGain(AUXADC_REF_FIXED), AUXADCGetAdjustmentOffset(AUXADC_REF_FIXED))); } adcVal_uV[4] = 0; int validMeasIdx; for (validMeasIdx = 0; validMeasIdx < 4; validMeasIdx++) { if (adcVal_uV[validMeasIdx] > OPTOSONDE_BROKEN_TEMP_SENSOR_THRESHOLD) { if (validMeasIdx == 3) { // Sensor is dead optosonde_data.reason = optosonde_reason_sensorfail; } } else { break; } } const int32_t ptcR = adcVal_uV[validMeasIdx] / pOutput->ntcIuA[validMeasIdx]; //const double ptcB25_100 = 3950; //const double rinf = 0.1763226979; // rinf = R0 * exp(-B/T0) //T = B / ln (R / rinf) //double ptcTemp = ptcB25_100 / log(ptcR / rinf) - 273.15;*/ TMP116_getTemp(tmp116Handle, TMP116_CELSIUS, &temp); optosonde_data.temp_deg_frac_8 =(int16_t) temp*256 ; while (!AONBatMonNewBatteryMeasureReady()) { // Wait Task_sleep(100 * 100 / Clock_tickPeriod); } optosonde_data.bat_20mV = (AONBatMonBatteryVoltageGet() * 390625) / 2000000; AONBatMonDisable(); if (PIN_getInputValue(IOID_8) == 0) { optosonde_data.reason = optosonde_reason_button; } // Init Tx task Task_Params_init(&txTaskParams); txTaskParams.stackSize = RFEASYLINKTX_TASK_STACK_SIZE; txTaskParams.priority = RFEASYLINKTX_TASK_PRIORITY + 1; txTaskParams.stack = &txTaskStack; txTaskParams.arg0 = (xdc_UArg) &optosonde_data; Task_construct(&txTask, rfEasyLinkTxFnx, &txTaskParams, NULL); } else { // Sensor failed sleepAndReset(10 * 60); } /* Acknowledge the alert event */ scifAckAlertEvents(); scifUninit(); } void sensorTask_fn(UArg arg0, UArg arg1) { AONBatMonEnable(); scifOsalInit(); scifOsalRegisterTaskAlertCallback(sendorTask_AlertCB); scifInit(&scifDriverSetup); scifExecuteTasksOnceNbl(1 << SCIF_ADCMEAS_TASK_ID); } void pinInt(PIN_Handle handle, PIN_Id pinId) { if (pinId == 8) { // Force reset to trigger measure and TX SysCtrlSystemReset(); } } /* * ======== main ======== */ int opto_main(void) { /* Call driver init functions. */ Board_initGeneral(); pin_handle = PIN_open(&pinState, pinTable); PIN_registerIntCb(pin_handle, pinInt); // Sensor task Task_Params_init(&sensorTaskParams); txTaskParams.stackSize = RFEASYLINKTX_TASK_STACK_SIZE; txTaskParams.priority = RFEASYLINKTX_TASK_PRIORITY; txTaskParams.stack = &sensorTaskStack; txTaskParams.arg0 = 0; txTaskParams.arg1 = 0; Task_construct(&sensorTask, sensorTask_fn, &sensorTaskParams, NULL); /* Start BIOS */ BIOS_start(); return (0); }
/* * Copyright (c) 2015-2016, Texas Instruments Incorporated * All rights reserved. * * Redistribution and use in source and binary forms, with or without * modification, are permitted provided that the following conditions * are met: * * * Redistributions of source code must retain the above copyright * notice, this list of conditions and the following disclaimer. * * * Redistributions in binary form must reproduce the above copyright * notice, this list of conditions and the following disclaimer in the * documentation and/or other materials provided with the distribution. * * * Neither the name of Texas Instruments Incorporated nor the names of * its contributors may be used to endorse or promote products derived * from this software without specific prior written permission. * * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */ /* * ======== rfEasyLinkTx.c ======== */ /* XDCtools Header files */ #include <stdlib.h> #include <xdc/std.h> #include <xdc/runtime/System.h> #include <xdc/runtime/Error.h> #include <semaphore.h> /* BIOS Header files */ #include <ti/drivers/rf/RF.h> #include <ti/sysbios/BIOS.h> #include <ti/sysbios/knl/Task.h> #include <ti/sysbios/knl/Clock.h> #include <ti/drivers/GPIO.h> #include <ti/drivers/I2C.h> /* TI-RTOS Header files */ #include <ti/drivers/PIN.h> #include <ti/drivers/Power.h> #include <ti/devices/cc13x0/driverlib/aon_batmon.h> #include <ti/devices/cc13x0/driverlib/aux_adc.h> #include <ti/devices/cc13x0/driverlib/chipinfo.h> #include <ti/devices/cc13x0/driverlib/sys_ctrl.h> #include <semaphore.h> #include <ti/sail/tmp116/tmp116.h> /* Board Header files */ #include "Board.h" /* EasyLink API Header files */ #include "easylink/EasyLink.h" #include "sc/scif.h" #include "version.h" #include "../sonde_gw_fw/sys_intf.h" #include <string.h> #include <math.h> #define RFEASYLINKTX_TASK_STACK_SIZE 1024 #define RFEASYLINKTX_TASK_PRIORITY 2 #define RFEASYLINKTX_BURST_SIZE 1 Task_Struct txTask; /* not static so you can see in ROV */ static Task_Params txTaskParams; static uint8_t txTaskStack[RFEASYLINKTX_TASK_STACK_SIZE]; Task_Struct sensorTask; /* not static so you can see in ROV */ static Task_Params sensorTaskParams; static uint8_t sensorTaskStack[RFEASYLINKTX_TASK_STACK_SIZE]; TMP116_Handle tmp116Handle ; I2C_Handle AppI2cHandle ; I2C_Transaction i2cTransaction; I2C_Params AppI2cParams; TMP116_Params tmp116Params; sem_t tmp116Sem; float temp; static PIN_State pinState; static PIN_Handle pin_handle; typedef struct { uint8_t reason; int16_t temp_deg_frac_8; uint8_t bat_20mV; } opto_sonde_data_t; //const int OPTOSONDE_BROKEN_TEMP_SENSOR_THRESHOLD = 1500 * 1000; // 1.5 V //#define OPTOSONDE_DEMO_MODE 1 PIN_Config pinTable[] = { PIN_ID(8) | PIN_INPUT_EN | PIN_PULLUP | PIN_HYSTERESIS, PIN_TERMINATE }; void sleepAndReset(uint32_t sleep_time_secs) { // Enable button interrupt wake up PIN_setInterrupt(pin_handle, PIN_ID(8) | PIN_IRQ_NEGEDGE); uint32_t secs = sleep_time_secs; while (secs > 0) { uint32_t sleep_s = secs > 2000 ? 2000 : secs; Task_sleep((sleep_s * 1000u * 1000) / Clock_tickPeriod); secs -= sleep_s; } SysCtrlSystemReset(); } void *tmp116AlertTask(void *arg0) { uint16_t data; while(1) { /* Pend on semaphore, tmp116Sem */ if (0 == sem_wait(&tmp116Sem)) { /* Reads status register, resetting the ALERT pin */ TMP116_readStatus(tmp116Handle, &data); } } } static void rfEasyLinkTxFnx(UArg arg0, UArg arg1) { opto_sonde_data_t* optosonde_data = (opto_sonde_data_t*) arg0; // rtc_cmd_t* rtc_cmd = arg1; // EasyLink_init(EasyLink_Phy_625bpsLrm); // EasyLink_init(EasyLink_Phy_5kbpsSlLr); EasyLink_init(EasyLink_Phy_Custom); /* * If you wish to use a frequency other than the default, use * the following API: * EasyLink_setFrequency(868000000); */ /* Set output power to 12dBm */ // EasyLink_setRfPwr(12); EasyLink_setRfPwr(10); EasyLink_TxPacket txPacket; // Fill packet data uint8_t payload_ptr = 0; // Payload version txPacket.payload[payload_ptr++] = (uint8_t) (0x0); // Src MAC EasyLink_getIeeeAddr(&txPacket.payload[payload_ptr]); payload_ptr += 8; // Copy data txPacket.payload[payload_ptr++] = (uint8_t) (optosonde_data->reason); txPacket.payload[payload_ptr++] = (uint8_t) (optosonde_data->temp_deg_frac_8 >> 8); txPacket.payload[payload_ptr++] = (uint8_t) (optosonde_data->temp_deg_frac_8); txPacket.payload[payload_ptr++] = (uint8_t) (optosonde_data->bat_20mV); // Firmware version memcpy(&txPacket.payload[payload_ptr], &VERSION_HASH, sizeof(VERSION_HASH)); payload_ptr += sizeof(VERSION_HASH); txPacket.len = payload_ptr; txPacket.absTime = 0; txPacket.dstAddr[0] = OPTOSONDE_ADDR; EasyLink_Status result = EasyLink_transmit(&txPacket); if (result == EasyLink_Status_Success) { /* Toggle LED1 to indicate TX */ // PIN_setOutputValue(pinHandle, Board_PIN_LED1,!PIN_getOutputValue(Board_PIN_LED1)); } else { /* Toggle LED1 and LED2 to indicate error */ // PIN_setOutputValue(pinHandle, Board_PIN_LED1,!PIN_getOutputValue(Board_PIN_LED1)); // PIN_setOutputValue(pinHandle, Board_PIN_LED2,!PIN_getOutputValue(Board_PIN_LED2)); } // Prevent button reset overload if (optosonde_data->reason == optosonde_reason_button) { Task_sleep(1000000 / Clock_tickPeriod); } // Tell RTC to sleep #ifdef OPTOSONDE_DEMO_MODE uint32_t sleep_time_s = 30; #elif OPTOSONDE_VITICODE uint32_t sleep_time_s = 10 * 60; #else uint32_t sleep_time_s = 1 * 3600; #endif sleepAndReset(sleep_time_s); } void sendorTask_AlertCB() { static opto_sonde_data_t optosonde_data; //I2C_init(); //TMP116_init(); /* Clear the ALERT interrupt source */ scifClearAlertIntSource(); /* Only handle the periodic event alert */ if (scifGetAlertEvents() & (1 << SCIF_ADCMEAS_TASK_ID)) { optosonde_data.reason = optosonde_reason_periodic; /* Get the SCE "output" structure */ SCIF_ADCMEAS_OUTPUT_T* pOutput = scifGetTaskStruct(SCIF_ADCMEAS_TASK_ID, SCIF_STRUCT_OUTPUT); //GPIO_init(); // GPIO_write(Board_TMP116_PWR, Board_TMP116_ON); //I2C_Params_init(&AppI2cParams); //AppI2cParams.transferMode = I2C_MODE_BLOCKING; //AppI2cParams.transferCallbackFxn = NULL; //AppI2cParams.bitRate = I2C_400kHz; //AppI2cHandle = I2C_open(CC1310_LAUNCHXL_I2C0, NULL); //if(AppI2cHandle == NULL){ /* Error opening I2C */ //while (1); //} //TMP116_Params_init(&tmp116Params); /* Callback for ALERT event */ //tmp116Handle = TMP116_open(Board_TMP007_ROOMTEMP, AppI2cHandle, &tmp116Params); //if (tmp116Handle == NULL) { //while(1); //} /* Allow the sensor hardware to complete its first conversion */ //TMP116_setTempLimit(tmp116Handle, TMP116_CELSIUS,(float)30.0F, (float)20.0F) ; /*int32_t adcVal_uV[5]; int i; for (i = 0; i < 4; i++) { adcVal_uV[i] = AUXADCValueToMicrovolts(AUXADC_FIXED_REF_VOLTAGE_NORMAL, AUXADCAdjustValueForGainAndOffset(pOutput->ntcraw[i], AUXADCGetAdjustmentGain(AUXADC_REF_FIXED), AUXADCGetAdjustmentOffset(AUXADC_REF_FIXED))); } adcVal_uV[4] = 0; int validMeasIdx; for (validMeasIdx = 0; validMeasIdx < 4; validMeasIdx++) { if (adcVal_uV[validMeasIdx] > OPTOSONDE_BROKEN_TEMP_SENSOR_THRESHOLD) { if (validMeasIdx == 3) { // Sensor is dead optosonde_data.reason = optosonde_reason_sensorfail; } } else { break; } } const int32_t ptcR = adcVal_uV[validMeasIdx] / pOutput->ntcIuA[validMeasIdx]; //const double ptcB25_100 = 3950; //const double rinf = 0.1763226979; // rinf = R0 * exp(-B/T0) //T = B / ln (R / rinf) //double ptcTemp = ptcB25_100 / log(ptcR / rinf) - 273.15;*/ //TMP116_getTemp(tmp116Handle, TMP116_CELSIUS, &temp); optosonde_data.temp_deg_frac_8 =(int16_t) temp*256 ; while (!AONBatMonNewBatteryMeasureReady()) { // Wait Task_sleep(100 * 100 / Clock_tickPeriod); } optosonde_data.bat_20mV = (AONBatMonBatteryVoltageGet() * 390625) / 2000000; AONBatMonDisable(); if (PIN_getInputValue(IOID_8) == 0) { optosonde_data.reason = optosonde_reason_button; } // Init Tx task Task_Params_init(&txTaskParams); txTaskParams.stackSize = RFEASYLINKTX_TASK_STACK_SIZE; txTaskParams.priority = RFEASYLINKTX_TASK_PRIORITY + 1; txTaskParams.stack = &txTaskStack; txTaskParams.arg0 = (xdc_UArg) &optosonde_data; Task_construct(&txTask, rfEasyLinkTxFnx, &txTaskParams, NULL); } else { // Sensor failed sleepAndReset(10 * 60); } /* Acknowledge the alert event */ scifAckAlertEvents(); scifUninit(); } void sensorTask_fn(UArg arg0, UArg arg1) { AONBatMonEnable(); scifOsalInit(); scifOsalRegisterTaskAlertCallback(sendorTask_AlertCB); scifInit(&scifDriverSetup); scifExecuteTasksOnceNbl(1 << SCIF_ADCMEAS_TASK_ID); } void pinInt(PIN_Handle handle, PIN_Id pinId) { if (pinId == 8) { // Force reset to trigger measure and TX SysCtrlSystemReset(); } } /* * ======== main ======== */ int opto_main(void) { /* Call driver init functions. */ Board_initGeneral(); pin_handle = PIN_open(&pinState, pinTable); PIN_registerIntCb(pin_handle, pinInt); // Sensor task Task_Params_init(&sensorTaskParams); txTaskParams.stackSize = RFEASYLINKTX_TASK_STACK_SIZE; txTaskParams.priority = RFEASYLINKTX_TASK_PRIORITY; txTaskParams.stack = &sensorTaskStack; txTaskParams.arg0 = 0; txTaskParams.arg1 = 0; Task_construct(&sensorTask, sensorTask_fn, &sensorTaskParams, NULL); /* Start BIOS */ BIOS_start(); return (0); }
