Part Number: CC1200
I am confusing about CCA_STATUS and CARRIER_SENSE signal shown in fig 16, pp38 in SWRU346B.
1) If CCA mode is "indicate clear channel when RSSI is below threshold", is CCA_STATUS same as CARRIER_SENSE?
2) Is the decision of TXONCCA done at every RSSI update timing?
3) If I need "CCA listening time" which consists of some RSSI update period, do I check every CCA_STATUS during the CCA listening time?
(What I am thinking is that if at least one RSSI period in CCA listening time is more than threshold, CCA result is busy.)
Thank you.
