Other Parts Discussed in Thread: CC1101, , CC1352R, CC1310
Dear E2E members,
I was redirected to this forum by TI Customer support. We are looking at possibilities to implement square-root raised cosine (RRC) pulse shaped QPSK transmission (100 ksymbols/second) for the sub-Ghz region (center frequency around 400.0 MHz), and I have come across CC1150(tx only)/CC1101. As long as I could find, TI does not supply any IC doing RRC-shaped QPSK directly, so my question is: using the "Asynchronous Transparent Transmit" mode, is it possibly to have access to the sent I/Q samples directly, so that we can implement our own modulation? If not, does TI have another IC which could do this at a low cost (<= $2 pp for on the order of 100k units), either directly or giving access to the I/Q samples (or using the IC in any other way to obtain RRC-shaped QPSK)?
Also, I would like to hear your thoughts on the CC13xx family, e.g. CC1310 or CC1352R: can I implement "custom" RRC QPSK with these?
Thanks in advance!
