CCS/LAUNCHXL-CC1310: RF_cmdPropTx transmits at wrong start time
Part Number: LAUNCHXL-CC1310
I have an application which is based on a modified version of the rfSynchronizedPacketTx/rfSynchrinizedPacketRx example. I have  the RF_cmdPrpTx to transmit a packet exactly every 2 seconds. What happens is that transmission goes on steadily at ever 2 seconds for about 6 minutes after which it starts transmitting a packet after every 18 minutes. Could you kindly explain to me how i can rectifiy such a situation.
settings:
 /******************************* Prepare the packet *********************************/
    RF_cmdPropTx.pktLen = sizeof(beacon);
    RF_cmdPropTx.pPkt = (uint8_t*)&beacon;
    RF_cmdPropTx.startTrigger.triggerType = TRIG_ABSTIME;
    RF_cmdFs.startTrigger.triggerType = TRIG_ABSTIME;
    RF_cmdFs.startTrigger.pastTrig = 1;
    RF_cmdPropTx.startTime = 0;
    beacon.beaconInterval = RF_convertMsToRatTicks(BEACON_INTERVAL_MS);
    RF_Params rfParams;
    RF_Params_init(&rfParams);
    rfHandle = RF_open(&rfObject, &RF_prop, (RF_RadioSetup*)&RF_cmdPropRadioDivSetup, &rfParams);
    assert(rfHandle != NULL);
    uint32_t swiPriority = 1;
    RF_control(rfHandle, RF_CTRL_SET_SWI_PRIORITY, &swiPriority);
    RF_EventMask result = RF_runCmd(rfHandle, (RF_Op*)&RF_cmdFs, RF_PriorityNormal, NULL, 0);
    assert((result == RF_EventLastCmdDone) && ((volatile RF_Op*)&RF_cmdFs)->status == DONE_OK);
    RF_cmdPropTx.startTime = RF_getCurrentTime();
    ntime = RF_cmdPropTx.startTime;
    RF_cmdPropTx.startTrigger.pastTrig = 1;
    PINCC26XX_setMux(pinHandle, Board_LED2, PINCC26XX_MUX_RFC_GPO1);
    StateMachine_setNextState(&stateMachine, PeriodicBeaconState);
execution
void PeriodicBeaconState_function()
   RF_cmdPropTx.startTime += RF_convertMsToRatTicks(BEACON_INTERVAL_MS);
    //vTime = RF_getCurrentTime();
    beacon.txTime = RF_cmdPropTx.startTime;
    beacon.ledState = PIN_getInputValue(Board_LED1);
    RF_EventMask result = RF_runCmd(rfHandle, (RF_Op*)&RF_cmdPropTx, RF_PriorityNormal, NULL, 0);   =================>>>( after 6 minutes it gets stuck here, and transmission then becomes ever 18mins)
    assert((result == RF_EventLastCmdDone) && ((volatile RF_Op*)&RF_cmdPropTx)->status == PROP_DONE_OK);
    PIN_setOutputValue(pinHandle, Board_LED1,!PIN_getOutputValue(Board_LED1));
    StateMachine_setNextState(&stateMachine, PeriodicBeaconState);  //always the case if its the sensor node
Thank you very much
    When transmission is every 18 mins, what is the value of RF_cmdPropTx.startTime before and after you do the following:
    R.M
  • Thanks for the response
    Transmission start (smartRF display)
    10:01:38.942 | 24 | 81 c4 88 05 00 12 7a 00 01 e0 82 c1 a1 0d c1 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | -28
    10:01:40.942 | 24 | 81 d6 02 06 00 12 7a 00 01 e0 82 c1 a1 0d c1 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | -28
    10:01:42.942 | 24 | 81 e8 7c 06 00 12 7a 00 01 e0 82 c1 a1 0d c1 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | -30
    10:07:20.917 | 24 | 81 ca 12 57 00 12 7a 00 01 e0 82 c1 a1 0d c1 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | -28
    10:07:22.917 | 24 | 81 dc 8c 57 00 12 7a 00 01 e0 82 c1 a1 0d c1 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | -28
    10:07:24.916 | 24 | 81 ee 06 58 00 12 7a 00 01 e0 82 c1 a1 0d c1 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | -28
    10:07:26.916 | 24 | 81 00 81 58 00 12 7a 00 01 e0 82 c1 a1 0d c1 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | -28 ==>> Halts after 6 minutes
    currentTime (BEFORE: RF_cmdPropTx.startTime += RF_convertMsToRatTicks(BEACON_INTERVAL_MS) = 1486859099
    RF_cmdPropTx.startTime time (AFTER: RF_cmdPropTx.startTime += RF_convertMsToRatTicks(BEACON_INTERVAL_MS) = 1492849281
    10:26:26.003 | 24 | 81 12 fb 58 00 12 7a 00 01 e0 82 c1 a1 0d c1 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | -29 ==>> Next trasnmission happens after 19 minutes
    currentTime (BEFORE: RF_cmdPropTx.startTime += RF_convertMsToRatTicks(BEACON_INTERVAL_MS) = 1492858966
    RF_cmdPropTx.startTime time (AFTER: RF_cmdPropTx.startTime += RF_convertMsToRatTicks(BEACON_INTERVAL_MS) = 1500849281
    10:45:09.370 | 24 | 81 24 75 59 00 12 7a 00 01 e0 82 c1 a1 0d c1 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | -27 ==>> Next trasnmission happens after 19 minutes
    currentTime (BEFORE: RF_cmdPropTx.startTime += RF_convertMsToRatTicks(BEACON_INTERVAL_MS) = 1500859077
    RF_cmdPropTx.startTime time (AFTER: RF_cmdPropTx.startTime += RF_convertMsToRatTicks(BEACON_INTERVAL_MS) = 1508849281
    Thank you
    Why do you set triggerType = TRIG_ABSTIME on both RF_cmdFs and RF_cmdPropTx?
    What value do you set RF_cmdFs.startTime to? The same as RF_cmdPropTx.startTime?
    You need to make sure there are enough time between RF_cmdFs.startTime and RF_cmdPropTx.startTime so that RF_cmdFs finish before the RF_cmdPropTx.startTime
    R.M
  • Understood. I commented out
    //RF_cmdFs.startTrigger.triggerType = TRIG_ABSTIME;
    and used it as done in rfSynchronizedPacketTx.c but still the same problem
    Thank you.
    Can you check and see what RF_getCurrentTime(); is after you have updated startTime with:
    I'm wondering if startTime is set to a time that is in the past already when the command is actually executed. We have seen that before and that will lead to a ~19 minutes delay before the command is executed.
    R.M
  • Thank you for the response,
    Actually i thought my previous post showed what u are requesting for
    So could you kindly let me know how you handled that case...
    "I'm wondering if startTime is set to a time that is in the past already when the command is actually executed. We have seen that before and that will lead to a ~19 minutes delay before the command is executed."
    Thank you.
    Emmanuel
  • Hi Emmanuel,
    Can you use the function RF_getCurrentTime() to read out the current time after you have updated  startTime (right before RF_runCmd)?
    uint32_t currentTime = RF_getCurrentTime();
    R.M
  • Hi R.M
    sure...
    Time before = 1490632323
     RF_cmdPropTx.startTime (after RF_cmdPropTx.startTime += RF_convertMsToRatTicks(BEACON_INTERVAL_MS)=1498632323
    uint32_t currentTime = RF_getCurrentTime(); = 1490647179
    thank you
    - emmanuel
  • Hi Emmanuel,
    I have been trying to reproduce what you are seeing but I have not so far.
    Questions:
    1. What SDK are you using?
    2. Can you confirm that you are running this on LAUNCHXL-CC1310 HW?
    3. Can you share your Tx project so I can try to reproduce using that?
    R.M
  • 1. I'm using the SimpleLink CC13x0 SDK 1.40.0.10
    2. Sure, I'm running it on the LAUNCHXL-CC1310 Eval Module Hardware
    3.
    #define RF_CTRL_SET_SWI_PRIORITY                  6
    #include "smartrf_settings/smartrf_settings.h"
    #include "Board.h"
    #include "StateMachine.h"
    #include <math.h>
    #include <nodetube.h>
    #include <msg.h>
    //#include "rfSynchronizedPacket.h"
    #include <N_rx_util.h>
    #include <N_task.h>
    /* stdlib */
    #include <stdbool.h>
    #include <stdlib.h>
    #include <stdint.h>
    #include <assert.h>
    /* TiRTOS Kernel */
    #include <ti/sysbios/BIOS.h>
    #include <ti/sysbios/knl/Task.h>
    /* High-level Ti-Drivers */
    #include <ti/drivers/pin/PINCC26XX.h>
    #include <ti/drivers/rf/RF.h>
    #include <driverlib/sys_ctrl.h>
    #include <driverlib/rom.h>
    #include <ti/devices/DeviceFamily.h>
    #include DeviceFamily_constructPath(driverlib/rf_common_cmd.h)
    #include DeviceFamily_constructPath(driverlib/rf_mailbox.h)
    #include DeviceFamily_constructPath(driverlib/rf_prop_cmd.h)
    #include DeviceFamily_constructPath(driverlib/rf_prop_mailbox.h)
    uint32_t rxTimestamp;
    uint32_t txTimestamp;
    uint32_t verifyTime;
    uint32_t vTime;
    uint8_t invCount,invCount2,invCount3,invCount4,invCount5,invCount6;
    uint8_t routeFlag;
    uint8_t checkResp=0;
    uint8_t firstNode;
    uint32_t sync_TT1 = 0;
    uint32_t calTime=0;
    uint32_t diffTime=0;
    uint8_t nName;
    uint8_t narr[10];
    uint8_t NodeDTCnt[10];
    uint8_t wakeFlag=1;
    uint8_t NetworkFail=0, target=0, PartialTCnt=0;
    uint8_t p, cnt_nodes=0, node_pos=0, changeTcounter=0, ccnt =0, nonewnode=0, newcount=0;
    uint8_t PacketSize = 13;
    uint8_t missedCounter=0, packetrec=0, q=0, k=0, wait_gnd=0;
    uint8_t try =0, proxy=0;
    uint8_t inc=0, resetcounter=0, redundant=0,resume_gnd=0;
    uint8_t AltNarr[10];
    uint8_t lastcounter=0, repeat_node=0,mpn=0;
    uint32_t OrderSentTime=0, time_now=0;
    uint32_t ntime =0;
    uint32_t qtime =0;
    uint32_t currentTime;
    uint32_t commandTime;
    //************************** Clock event for update of received data**************************************/
    static Clock_Struct stateClock;
    uint8_t holdID;
    uint8_t holdsrc;
    /*************************** Advanced TX command for sending long preamble *******************************/
    //rfc_CMD_PROP_TX_t RF_cmdPropTx;
    //enum rf_mode  {
    //    RX_MODE,
    //    TX_MODE,
    uint16_t me = 0;
    /************************ Define events that can be posted to the application state machine ***************/
    typedef enum {
        Event_PacketReceived = StateMachine_Event00,
        Event_SyncMissed = StateMachine_Event01,
        Event_NewMissed = StateMachine_Event02,
    } Event;
    /******************************* Declare state handler functions for the application. **********************/
    StateMachine_DECLARE_STATE(PrepareSyncedRxState);
    StateMachine_DECLARE_STATE(PrepareSyncedTxState);
    StateMachine_DECLARE_STATE(WaitingForSyncState);
    StateMachine_DECLARE_STATE(SyncedRxState);
    StateMachine_DECLARE_STATE(SyncedTxRxState);
    StateMachine_DECLARE_STATE(PreapareSyncedRxTxState);
    StateMachine_DECLARE_STATE(PeriodicBeaconState);
    /***** Defines *****/
    #define MAIN_TASK_STACK_SIZE 1024
    #define MAIN_TASK_PRIORITY   2
    /* Packet RX Configuration */
    #define NUM_APPENDED_BYTES     5  /* The Data Entries data field will contain:
     * - 1 address byte in the header (RF_cmdPropRx.rxConf.bIncludeHdr = 0x1)
     * - up to sizeof BeaconPacket bytes payload
     * - 4 bytes for the RAT time stamp (RF_cmdPropRx.rxConf.bAppendTimestamp = 0x1) */
    #define SYMBOL_RATE            200000//50000                    /* 50 kbits per second */
    #define US_PER_SYMBOL          (1000000 / SYMBOL_RATE)
    #define PREAMBLE_BITS          32
    #define SYNCWORD_BITS          32
    #define BEACON_INTERVAL_MS     2000//2000
    #define RX_START_MARGIN        RF_convertUsToRatTicks(500)   /* An arbitrarily chosen value to compensate for
     * the potential drift of the RAT and the RTC. */
    #define RX_TIMEOUT_TICKS       RF_convertUsToRatTicks((PREAMBLE_BITS + SYNCWORD_BITS) * US_PER_SYMBOL)
    /* Tight, but ideal duration for receiving all bits of
     * the preamble and the sync word. */
    #define RX_TIMEOUT_MARGIN      RF_convertUsToRatTicks(1000)  /* Arbitrarily chosen margin added to the RX timeout
     * to compensate calculation errors. */
    #define RX_START_TO_SETTLE_TICKS   256 /* Time between RX start trigger and the radio
     * being ready to receive the first preamble bit.
     * This is a fixed value for CMD_PROP_RX. */
    #define TX_START_TO_PREAMBLE_TICKS 384 /* Time between TX start trigger and first bit on air.
     * This is a fixed value for CMD_PROP_TX. */
    /***** Variable declarations *****/
    Task_Struct mainTask;    /* not static so you can see in ROV */
    static uint8_t mainTaskStack[MAIN_TASK_STACK_SIZE];
    static StateMachine_Struct stateMachine;
    static RF_Object rfObject;
    static RF_Handle rfHandle;
    /* Queue object that the RF Core will fill with data */
    static dataQueue_t rxQueue;
    /* A single queue item that points to a data buffer  */
    static rfc_dataEntryPointer_t rxItem;
    /* Word-aligned buffer for the packet payload + meta data. */
    static uint8_t rxBuffer[((sizeof(BeaconPacket) + NUM_APPENDED_BYTES) + 8)];
    BeaconPacket beacon;
    nodeQ* head;
    /***** Prototypes *****/
    //void StateTask_init();
    void WORcallback(RF_Handle h, RF_CmdHandle ch, RF_EventMask e);
    void PrepareSyncedRxState_function();
    void PrepareSyncedTxState_function();
    void PeriodicBeaconState_function();
    void SyncedRxState_rxCallback(RF_Handle h, RF_CmdHandle ch, RF_EventMask e);
    void SyncedTxRxState_txrxCallback(RF_Handle h, RF_CmdHandle ch, RF_EventMask e);
    void WaitingForSyncState_rxCallback(RF_Handle h, RF_CmdHandle ch, RF_EventMask e);
    void configureTx();
    void TransmitTx();
    void configureRx();
    static void ClockSwiFxn(uintptr_t arg0);
    void errorCallback(RF_Handle h, RF_CmdHandle ch, RF_EventMask e);
    /*****************************INITIALIZE MACHINE STATE TASK*************************************************************************/
    /* Comment: set to PrepareSyncedTxState
    void StateTask_init(PIN_Handle ledPinHandle)
        //******************** Initialize Clock for Timouts************************************/
        Clock_Params clockParams;
        Clock_Params_init(&clockParams);
        //*********************Target Response Clock*******************************************/
        clockParams.period = 20 * (1000/Clock_tickPeriod), // 1000 ms, conversion from ms to clock ticks.
                // Initialize the clock object / Clock_Struct previously added globally.
                Clock_construct(&stateClock, ClockSwiFxn,
                                0, // Initial delay before first timeout
                                &clockParams);
        pinHandle = ledPinHandle;
        //*********************** Initialise the application state machine.********************/
        StateMachine_construct(&stateMachine);
        /* Initialise the main task. It will execute
         * the state machine StateMachine_exec() function.
        Task_Params params;
        Task_Params_init(&params);
        params.stackSize = MAIN_TASK_STACK_SIZE;
        params.priority = MAIN_TASK_PRIORITY;
        params.stack = &mainTaskStack;
        params.arg0 = (UArg)&stateMachine;
        params.arg1 = (UArg)PrepareSyncedTxState_function;
        Task_construct(&mainTask, (Task_FuncPtr)&StateMachine_exec, &params, NULL);
    /*****************************PREPARED_SYNCED_RX_STATE_FUNCTION*************************************************************************/
    /* Comment:
        if(tricklastnode==1)
            Semaphore_pend(semTxHandle, BIOS_WAIT_FOREVER); //proper fix later
        /************************* Construct a circular RX queue with a single pointer-entry item. ******************/
        rxItem.config.type = DATA_ENTRY_TYPE_PTR;
        rxItem.config.lenSz = 0;
        rxItem.length = sizeof(rxBuffer);
        rxItem.pNextEntry = (uint8_t*)&rxItem;
        rxItem.pData = (uint8_t*)&rxBuffer[0];
        rxItem.status = DATA_ENTRY_PENDING;
        rxQueue.pCurrEntry = (uint8_t*)&rxItem;
        rxQueue.pLastEntry = NULL;
        /************************* Modify CMD_PROP_RX command for application needs **********************************/
        RF_cmdPropRx.pQueue = &rxQueue;                /* Set the Data Entity queue for received data */
        RF_cmdPropRx.rxConf.bAutoFlushIgnored = true;  /* Discard ignored packets from Rx queue */
        RF_cmdPropRx.rxConf.bAutoFlushCrcErr = true;   /* Discard packets with CRC error from Rx queue */
        RF_cmdPropRx.rxConf.bIncludeHdr = true;        /* Put length field in front of queue entries. */
        RF_cmdPropRx.rxConf.bAppendTimestamp = true;   /* Append RX time stamp to the packet payload */
        RF_cmdPropRx.maxPktLen = sizeof(BeaconPacket); /* Implement packet length filtering to avoid PROP_ERROR_RXBUF */
        RF_cmdPropRx.pktConf.bRepeatOk = false;        /* Stop after receiving a single valid packet */
        RF_cmdPropRx.pktConf.bRepeatNok = true;
        RF_cmdPropRx.pOutput   = (uint8_t*)&rxStatistics;
        /***************** Request access to the radio. This does not power-up the RF core, but only initialise
         * the driver and cache the setup command. ********************************************************************/
        RF_Params rfParams;
        //rfParams.nPowerUpDurationMargin = 315;
        /* Set the frequency. Now the RF driver powers the RF core up and runs the setup command from above.
         * The FS command is executed and also cached for later use when the RF driver does an automatic
         * power up. */
        /* Route the LNA signal to an LED to indicate that the RF core is
         * active and receiving data.
         * Available signals are listed in the proprietary RF user's guide.
        PINCC26XX_setMux(pinHandle, Board_LED2, PINCC26XX_MUX_RFC_GPO0);
        StateMachine_setNextState(&stateMachine, WaitingForSyncState);
    /*****************************************PREPARE_SYNCED_TX_STATE FUNCTION***************************************************************/
    /* Comment:
        Semaphore_pend(semRxHandle, BIOS_WAIT_FOREVER);
        //    RF_cmdPropTx.startTrigger.pastTrig = 1;
        if(routeFlag)
            //prepare routing packet*******************************/
            beacon.msg.startbit = RF_STX;
            beacon.msg.mid = MSGID_REQ_NARR_AGAIN;
            beacon.msg.src = theNode.myid;
            beacon.msg.des = 0xFF;
            beacon.msg.msgl= newcount+cnt_nodes-(node_pos);//node_count;//0x05;
            uint8_t nCon = 0x0B;
            nodeQ* temp;
            temp = head;
            for (q=0; q<newcount; q++)
                beacon.msg.data[q]=temp->nodeid;
                temp = temp->next;
                if((beacon.msg.data[q] & 0xF0)==0xC0)
                    if(q==0)
                        beacon.msg.data[0]=beacon.msg.data[q];
                    else
                        firstNode =  beacon.msg.data[0];
                        for(k=1;k<q;k++)
                            beacon.msg.data[k+2]=beacon.msg.data[k];
                        beacon.msg.data[1]=firstNode;
            for(q=0; q<(cnt_nodes-node_pos); q++)
                beacon.msg.data[q+newcount] = (nCon<<4) | (narr[node_pos+q]);
            for(q=0; q<(newcount+cnt_nodes-(node_pos)); q++)
                narr[q]=beacon.msg.data[q];
            cnt_nodes=newcount+cnt_nodes-(node_pos);
            node_pos=newcount;
        if(wait_gnd)
            beacon.msg.mid = MSGID_SYSTEM_RESET_FB;//MSGID_ACK_PRESENCE;
            beacon.msg.des = mpn;//(nCon<<4) | target;
            beacon.msg.msgl= 0x04;
        if(resume_gnd)
            beacon.msg.mid = MSGID_DATA_SENSOR;//MSGID_ACK_PRESENCE;
            beacon.msg.des = (nCon<<4) | target;
        //RF_close(rfHandle);
        /* Request access to the radio. This does not power-up the RF core, but only initialise
         * the driver and cache the setup command. */
        RF_Params rfParams;
        //    rfParams.nPowerUpDurationMargin = 5000;
        //    rfParams.pErrCb = errorCallback;
        //    rfParams.nPowerUpDuration = 10000;
        /* Increase the SWI priority of the internal state machine in the RF driver. The default
         * value is 0. This is necessary because the button callback blocks for a long time and
         * might disturb the RF driver state machine.
         * power up. */
        /* Use the current time as an anchor point for future time stamps.
         * The Nth transmission in the future will be exactly N * 500ms after
         * this time stamp.  */
        /* A trigger in the past is triggered as soon as possible.
         * No error is given.
         * This avoids assertion when button debouncing causes delay in TX trigger.  */
        //RF_cmdPropTx.startTrigger.pastTrig = 1;
        /* Route the PA signal to an LED to indicate ongoing transmissions.
    /*****************************ERROR CALLBACK FUNCTION*************************************************************************/
    /* Comment:
    void errorCallback(RF_Handle h, RF_CmdHandle ch, RF_EventMask e) {
        if ((int32_t)ch == RF_ERROR_CMDFS_SYNTH_PROG)
            while(1);
            // Handle error
            // If CMD_FS is executed standalone, re-start CMD_FS in this function if there is time. If not, handle as in previous example
            // When CMD_FS is chained with RX/TX commands, the RX/TX is executed in parallel with this callback by the radio and will subsequently fail. Error can be handled as in previous example.
        else
            while(1);
    /*****************************WAITING_FOR_SYNC_STATE_FUNCTION*************************************************************************/
    /* Comment:
    void WaitingForSyncState_function()
        /***************************** Start RX command to receive a single packet. **************************/
        RF_cmdPropRx.startTrigger.triggerType = TRIG_NOW;
        if((tricklastnode) & (wait_gnd == 0))
            RF_cmdPropRx.endTrigger.triggerType = TRIG_REL_START;
            RF_cmdPropRx.endTrigger.pastTrig = 1;
            RF_cmdPropRx.endTime = 12000000;
        else if((missedCounter>node_pos) & (wait_gnd == 0))
            RF_cmdPropRx.endTime = 20000000 + (node_pos*12000000);
        else if(wait_gnd)
            RF_cmdPropRx.endTrigger.triggerType = TRIG_NEVER;
            //wait_gnd=0;
        else
        RF_postCmd(rfHandle, (RF_Op*)&RF_cmdPropRx, RF_PriorityNormal, &WaitingForSyncState_rxCallback, RF_EventRxEntryDone);
        for (;;)
            time_now = RF_getCurrentTime();
            if(nonewnode & tricklastnode)
                nonewnode=0;
                if(checkResp==1)
                    if(proxy)
                        tricklastnode=0;
                        proxy=0;
                    routeFlag =1;
                    lastcounter=0;
                    checkResp=0;
                    StateMachine_setNextState(&stateMachine, PrepareSyncedTxState);
                    Semaphore_post(semRxHandle);
                else
                    routeFlag=0;
                    //tricklastnode=1; //how does affect other scenarios
                    missedCounter=0;
                    inc=0;
                    lastcounter=0;
                    //nName=0xB0 + narr[node_pos+1];
                    //break;
                RF_close(rfHandle);
                break;
            if(packetrec)
                packetrec=0;
                StateMachine_EventMask events = StateMachine_pendEvents(&stateMachine, Event_PacketReceived| Event_SyncMissed | Event_NewMissed, BIOS_WAIT_FOREVER);
                if (events & Event_PacketReceived)
                    /********************* RX command has already stopped. Now examine the received data. *************************/
                    uint8_t length;
                    uint32_t rxTime;
                    memcpy(&length, rxBuffer, 1);
                    if (length != sizeof(BeaconPacket))
                        // This packet is not for us. Wait for next one
                        break;
                    memcpy(&beacon, (uint8_t*)rxBuffer + 1, sizeof(BeaconPacket));
                    memcpy(&rxTime, (uint8_t*)rxBuffer + 1 + sizeof(BeaconPacket), 4);
                    PIN_setOutputValue(pinHandle, Board_LED2,!PIN_getOutputValue(Board_LED2));
                    if((beacon.msg.mid==MSGID_REQ_NARR) || (beacon.msg.mid==MSGID_REQ_NARR_AGAIN))
                        if((beacon.msg.mid==MSGID_REQ_NARR_AGAIN))
                            for(p=0; p<cnt_nodes; p++)
                                narr[p] = 0x00; //a router table reset here
                            cnt_nodes=0;
                        //condition if its just the sensor node
                        if((beacon.msg.data[0] & 0xF0) ==0xC0)
                        { p=1;
                        cnt_nodes=1;
                        narr[0] = (beacon.msg.data[0] & 0x0F);
                        else
                            p=0; //reset p
                        for(p; p<beacon.msg.msgl; p++ )
                            if((beacon.msg.data[p] & 0xF0)==0xB0)
                                cnt_nodes++;
                            narr[p] = (beacon.msg.data[p] & 0x0F); //populate with the NNs the B's
                        //*************************************you're the sensor node************************/
                        if(beacon.msg.data[0]==theNode.myid)
                            if((beacon.msg.mid==MSGID_REQ_NARR_AGAIN) & (cnt_nodes<2))
                                nName=beacon.msg.src;
                            else if((beacon.msg.mid==MSGID_REQ_NARR) & (cnt_nodes<2))
                                nName = 0xA1;
                            else
                                nName = beacon.msg.data[1];
                            if((theNode.myid & 0xF0)!=0xC0)//you are unofficial sensor node OxBX
                                tricklastnode=1;
                            RF_close(rfHandle);
                            node_pos=0;
                            break;
                        for(p=1; p<(cnt_nodes-1); p++ )
                            if(beacon.msg.data[p]==theNode.myid)
                                nName = beacon.msg.data[p+1];
                                node_pos = p;
                        if(beacon.msg.data[(cnt_nodes-1)]==theNode.myid)
                            nName = 0xA1;
                            node_pos = cnt_nodes - 1;
                    if(beacon.msg.mid==MSGID_SYSTEM_RESET_FB  && beacon.msg.des == theNode.myid)
                        if((theNode.myid & 0xF0) == 0xC0)
                            wait_gnd=0;
                            resume_gnd=1;
                            RF_close(rfHandle);
                            break;
                        else if(((theNode.myid & 0xF0) == 0xB0) && (tricklastnode==1))
                            wait_gnd=0;
                            resume_gnd=1;
                            RF_close(rfHandle);
                            break;
                        else
                            //wait_gnd=0;
                            RF_close(rfHandle);
                            break;
                    if(beacon.msg.mid==MSGID_DATA_SENSOR  && beacon.msg.des == theNode.myid)
                        //if(beacon.msg.des==theNode.myid)
                        mpn=beacon.msg.src;
                            missedCounter=0;
                            changeTcounter=0;
                            inc=0;
                            RF_cmdPropRx.startTime = rxTime - RX_START_TO_SETTLE_TICKS - RX_START_MARGIN;
                            target = (theNode.myid & 0x0F);
                            StateMachine_setNextState(&stateMachine, SyncedTxRxState);
                            break;
                    if(beacon.msg.mid==MSGID_ACK_PRESENCE  && beacon.msg.des == theNode.myid)
                            wait_gnd=0;
                        //ntime=0;
                        break;
                    //                if(beacon.msg.mid==ID_SYSTEM_RESET  && beacon.msg.des == theNode.myid)
                    //                    SysCtrlSystemReset();
                    //Arrangement of the normal nodes and sensor nodes based on RSSI*********************************************************/
                    if((beacon.msg.mid == MSGID_REQ_JOIN_AGAIN && (beacon.msg.src & 0xF0)==0xB0 && beacon.msg.des==theNode.myid) || (beacon.msg.mid == MSGID_REQ_JOIN_AGAIN && (beacon.msg.src & 0xF0)==0xC0 && beacon.msg.des==theNode.myid))
                        repeat_node=0;
                        if((beacon.msg.src & 0xF0)==0xC0)
                            proxy=1;
                        if((beacon.msg.src & 0xF0)!=0xC0)
                            for(p=0; p<(cnt_nodes-node_pos); p++)
                                if((beacon.msg.src & 0x0F)==narr[p+node_pos])
                                    repeat_node=1;
                        if(repeat_node==0)
                            head = prepend(head,beacon.msg.src,RSSIout);
                            head = insertion_sort(head);
                            newcount++;
                        missedCounter=0;
                        inc=0;
                        checkResp=1;
                    if(missedCounter>node_pos)
                        if(beacon.msg.mid==MSGID_DATA_SENSOR & beacon.msg.des != theNode.myid )
                            changeTcounter++;
                            if( (beacon.msg.des & 0x0F)==narr[node_pos-inc])
                                changeTcounter=0;
                                target = narr[node_pos-inc];
                                missedCounter=0;
                                inc=0;
                                break;
                            else if((changeTcounter>node_pos*2) & ((node_pos-inc) !=0))
                                inc++;
                                changeTcounter=0;
                                break;
                            else if((node_pos-inc) ==0)
                                changeTcounter=0;
                                missedCounter=0;
                                inc=0;
                                break;
                    /* rxTime contains a calculated time stamp when the first preamble byte
                     * was sent on air. As a time base for the next wake ups, we calculate
                     * the time when this RX command would have been started for a synchronized
                     * wake up. */
                    break;
                if (events & Event_SyncMissed)
                    tricklastnode=1;
                    break;
    /*****************************************WAITING_FOR_SYNC_STATE_RXCALLBACK FUNCTION***************************************************************/
    /* Comment:
        if (e & RF_EventLastCmdDone)
            if ((RF_cmdPropRx.status == PROP_DONE_OK) || (RF_cmdPropRx.status == PROP_DONE_ENDED))
                /**************************** Sync word has been found before end trigger and packet has been received ******************/
                StateMachine_postEvents(&stateMachine, Event_PacketReceived);
                packetrec=1;
            else
                if(tricklastnode)
                    nonewnode=1;
                    //StateMachine_setNextState(&stateMachine, WaitingForSyncState);
                else if((missedCounter>node_pos) & (!tricklastnode))
                    StateMachine_postEvents(&stateMachine, Event_SyncMissed);
                    packetrec=1;
                //StateMachine_setNextState(&stateMachine, PeriodicBeaconState);
                // Everything else is an error.
                else
                    assert(false);
    // Remember to fix gap
    /*****************************************SYNCED_RX_STATE FUNCTION***************************************************************/
    /* Comment:
    void SyncedRxState_function()
        /* Start RX command to receive a single packet. Use an absolute start trigger
         * and a predicted start time. The end time is calculated to be as tight as possible.
         * The compensation margin for RAT drift in both directions needs to be taken into account.  */
        RF_cmdPropRx.startTrigger.triggerType = TRIG_ABSTIME;
        RF_cmdPropRx.startTime += beacon.beaconInterval;
        RF_cmdPropRx.endTime = RX_START_TO_SETTLE_TICKS + RX_TIMEOUT_TICKS + RX_TIMEOUT_MARGIN + RX_START_MARGIN;
        /* Puts the RX command into the driver queue. Since the start trigger is absolute and has
         * a time somewhere in the future, the RF driver will power down the RF core and wait short
         * before the RX command is due. Then it will run the power-up sequence and dispatch the RX
         * command right on time.
        RF_CmdHandle cmd = RF_postCmd(rfHandle, (RF_Op*)&RF_cmdPropRx, RF_PriorityNormal, &SyncedRxState_rxCallback, RF_EventRxEntryDone);
        for (;;)
            StateMachine_EventMask events = StateMachine_pendEvents(&stateMachine, Event_PacketReceived | Event_SyncMissed, BIOS_WAIT_FOREVER);
                /* RX command has already stopped. Now examine the received data. */
                uint8_t length;
                uint32_t rxTime;
                    StateMachine_setNextState(&stateMachine, SyncedRxState);
                    break;
                /* The synchronisation offset might be used to calculate the clock drift between tranStateMachine_itter and receiver. */
                int32_t syncOffsetTime = rxTime - RX_START_TO_SETTLE_TICKS /*RX_START_MARGIN*/ - RF_cmdPropRx.startTime;
                (void)syncOffsetTime; // need to reference the variable to prevent from a compiler warning
                /* Do an immediate re-synchronisation based on the new RX time. */
                RF_cmdPropRx.startTime = rxTime - RX_START_TO_SETTLE_TICKS - RX_START_MARGIN;// - syncOffsetTime;
                //PIN_setOutputValue(pinHandle, Board_LED1, beacon.ledState);
                /* Wait for the next packet */
                break;
                /* Sync is missed. That means either we are out of sync or the
                 * tranStateMachine_itter is in spontaneous mode. Try to receive the next packet. */
                me++;
                if(me==5)
                break;
    /*****************************************SYNCED_RX_STATE_RXCALLBACK FUNCTION***************************************************************/
    /* Comment:
                /* Sync word has been found before end trigger and packet has been received */
            else if (RF_cmdPropRx.status == PROP_DONE_RXTIMEOUT)
    /*****************************************PERIODIC_BEACON_STATE FUNCTION***************************************************************/
    /* Comment:
        //RF_cmdPropTx.startTime = RF_getCurrentTime();
        /* Set absolute TX time in the future to utilise "deferred dispatching of commands with absolute timing".
         * This is explained in the proprietary RF user's guide. */
        //invCount++;
        //ntime = RF_getCurrentTime();
        //ntime += (uint32_t)(4000000*2.0f);// RF_convertMsToRatTicks(BEACON_INTERVAL_MS);
        if(routeFlag)
            //StateMachine_setNextState(&stateMachine, PrepareSyncedRxState);
            RF_close(rfHandle);
            if(newcount)
                tricklastnode=0;
            else
            routeFlag=0;
            newcount=0;
        else if (wait_gnd)
            RF_close(rfHandle);
            wait_gnd = 0;
            beacon.msg.mid=0x01;
        else
            if( holdID==TRANSMIT_WAKEUP_AGAIN) //restructure the crude construction
                nName=holdsrc;
                holdID=0;
                holdsrc=0;
                beacon.msg.mid=MSGID_REQ_JOIN_AGAIN;
            beacon.msg.des =nName;
            beacon.msg.src =theNode.myid;
            beacon.msg.msgl = PacketSize;
            /* Because the TX command is due in 500ms and we use TRIG_ABSTIME as start trigger type,
             * the RF driver will now power down the RF core and and wait until ~1.5ms before RF_cmdPropTx.startTime.
             * Then the RF driver will power-up the RF core, re-synchronise the RAT and re-run the setup procedure.
             * The setup procedure includes RF_cmdPropRadioDivSetup and RF_cmdFs from above.
             * This will guarantee that RF_cmdPropTx is delivered to the RF core right before it has
             * to start. This is fully transparent to the application. It appears as the RF core was
             * never powered down.
             * This concept is explained in the proprietary RF user's guide. */
            if(beacon.msg.mid==MSGID_REQ_JOIN_AGAIN)
                //beacon.msg.mid=MSGID_REQ_JOIN;
                RF_close(rfHandle);
                //invCount6++;
                //while(1);
            else if(beacon.msg.mid==0x00)
                RF_close(rfHandle);
            else
                for(q=0;q<MAXMSGLENGTH;q++)
                    beacon.msg.data[q] = 0x00; //reset data array
                //resetcounter++;            /*******************************FOR FEEDBACK TEST************************/
                beacon.msg.data[0] = theNode.myid;
                beacon.msg.data[1] = 0xff;
                beacon.msg.data[2] = 0xff;
                int j;
                for(j=3;j<PacketSize;j++)//for now dummy data
                    beacon.msg.data[j] = (j-2);
                if(resetcounter >32)   //after 32 packets send this reset info for confirmation
                    beacon.msg.mid = ID_SYSTEM_RESET;
                ////////////////////////////////////////////////////Some Hack - TRANSMISSION TIME BOUNDS//////////////////////////////////////////////////
                //            // Current timestamp:
                //            currentTime = RF_getCurrentTime();
                //            // Command's start time
                //            commandTime = RF_cmdPropTx.startTime;
                //            // Assume that a command can be scheduled max 3s ahead
                //            const maxTimeAhead = 1000000*8;
                //            // ... and must be min 100�s ahead (time to deliver to RF core, parsing, ...)
                //            const minTimeAhead = 1000*4;
                //            uint32_t timeUntilStart = commandTime - currentTime;
                //            //            // Ensure that the constraints are satisfied
                //            assert(timeUntilStart >= minTimeAhead);
                //            assert(timeUntilStart <= maxTimeAhead);
                //            invCount5++;
                //unsigned int invCount55 = RF_cmdPropTx.startTime;
                // if(invCount5==176 && (beacon.msg.src & 0xF0)==0xC0)
                // Abort anything
                //                HapiResetDevice();
                //            else if (invCount5==176 && (beacon.msg.src & 0xF0)==0xB0)
                //                StateMachine_setNextState(&stateMachine, PrepareSyncedRxState);
                //            else
                    //if(invCount5!=176)
                    //                RF_CmdHandle ch = RF_postCmd(rfHandle, (RF_Op*)&RF_cmdPropTx, RF_PriorityNormal, NULL,RF_EventRxEntryDone);
                    //                invCount6++;
                    //                                PIN_setOutputValue(pinHandle, Board_LED1,!PIN_getOutputValue(Board_LED1));
                    //                                StateMachine_setNextState(&stateMachine, PeriodicBeaconState);  //always the case if its the sensor node
                    //                            RF_close(rfHandle);
                    //                            configureTx();
                    //                invCount6++;
                    //SysCtrlSystemReset();
                    //while(1);
                    // PeriodicBeaconState_function() will be entered again.
                    if((lastcounter<9) & (resetcounter < 34))
                    if(resetcounter >33)
                        resetcounter = 0;
                        RF_close(rfHandle);
                        lastcounter++;
                    if(lastcounter==10)
                        MsgObj msg;
                        lastcounter=0;
                        msg.cmdid= START_RADIO_AGAIN;
                        msg.cmds = 0x09;
                        msg.smsg.mid = MSGID_REQ_WAKEUP_AGAIN;
                        msg.smsg.src = theNode.myid;
                        msg.smsg.des = 0xFF;
                        msg.smsg.msgl = packetLength;
                        Mailbox_post(mbxHandle, &msg, BIOS_NO_WAIT);
    /*****************************************SYNCED_TX_RX_STATE FUNCTION***************************************************************/
    /* Comment:
    void SyncedTxRxState_function()
        qtime = RF_cmdPropRx.startTime;
        RF_CmdHandle cmd = RF_postCmd(rfHandle, (RF_Op*)&RF_cmdPropRx, RF_PriorityNormal, &SyncedTxRxState_txrxCallback, RF_EventRxEntryDone);
        RSSIout = rxStatistics.lastRssi;
        for (;;)
            StateMachine_EventMask events = StateMachine_pendEvents(&stateMachine, Event_PacketReceived | Event_SyncMissed | Event_NewMissed, BIOS_WAIT_FOREVER);
                uint8_t length;
                uint32_t rxTime;
                    break;
                int j;
                if((rxBuffer[13] & 0x0F)==target)//if my data
                    Clock_start(Clock_handle(&stateClock));
                    ///////////////////////////////////lets do our manipulations here///////////////////////////////////////
                    int32_t syncOffsetTime = rxTime - RX_START_TO_SETTLE_TICKS /*RX_START_MARGIN*/ - qtime/*RF_cmdPropRx.startTime*/;
                    //20ms then transmit package
                    while(wakeFlag==1);
                    if(wakeFlag==0)
                        wakeFlag=1; //reset
                        if (Clock_isActive(Clock_handle(&stateClock))){
                            Clock_stop(Clock_handle(&stateClock));
                        beacon.msg.des =nName;//beacon.msg.data[1];
                        beacon.msg.data[(node_pos*PacketSize)] = theNode.myid;
                        beacon.msg.data[1+(node_pos*PacketSize)] = RSSIout;
                        beacon.msg.data[2+(node_pos*PacketSize)] = 0xff;
                        for(j=3;j<beacon.msg.msgl;j++)//for now dummy data
                            beacon.msg.data[j+(node_pos*PacketSize)] = (node_pos*10)+(j-2);
                        calTime = RF_getCurrentTime();
                        if(rxBuffer[11] == ID_SYSTEM_RESET)
                        RF_close(rfHandle);
                        configureTx();
                        TransmitTx();
                        RF_close(rfHandle);
                        configureRx();
                        if(beacon.msg.mid == ID_SYSTEM_RESET)
                            if(redundant)
                                resume_gnd=0;
                                redundant=0;
                                wait_gnd = 1;
                                break;
                            redundant++;
                        break;
                missedCounter++;
                    if((node_pos-inc) == 0)
                        //beacon.msg.mid =MSGID_DATA_SENSOR;
                        //nName = 0xB0 + narr[node_pos+1];
                        tricklastnode = 1;
                        routeFlag=0;
                        //Semaphore_post(semRxHandle);
                        break;
                    break;
                else
                    break;
            if (events & Event_NewMissed)
                //StateMachine_setNextState(&stateMachine, SyncedTxRxState);
                //me++;
                //if(me==5)
                break;
    /*****************************************SYNCED_TX_RX_STATE_TXRXCALLBACK FUNCTION***************************************************************/
    /* Comment:
            else
                StateMachine_postEvents(&stateMachine, Event_NewMissed);
    /*****************************************CONFIGURE_TX FUNCTION**************************************************************************/
    /* Comment:
    void configureTx()
        //Semaphore_pend(semRxHandle, BIOS_WAIT_FOREVER);
        /* Prepare the packet */
        RF_Params rfParams;
         * power up. */
        //PINCC26XX_setMux(pinHandle, Board_LED2, PINCC26XX_MUX_RFC_GPO1);
    /*****************************************TRANSMIT_TX FUNCTION***************************************************************/
    /* Comment:
    void TransmitTx()
        //RF_cmdPropTx.startTime += RF_convertMsToRatTicks(BEACON_INTERVAL_MS);
    /*****************************************CONFIGRURE_RX FUNCTION*************************************************************************/
    /* Comment:
    void configureRx()
        RF_Params rfParams;
         * power up. */
        //PINCC26XX_setMux(pinHandle, Board_LED2, PINCC26XX_MUX_RFC_GPO0);
        //reset flag.
        wakeFlag=0;
  • Hi Emmanuel,
    Can you share your entire Tx Project? You only shared one .c file.
    If you do not want to share on this public forum please send me a friend request.
    R.M
  • Closing this thread due to lack of feedback
