Part Number: CC1200
Dear All,
We want to handle CCA functionality for our CC1200 866 MHz radio. How we can setup our threshold properly. We want threshold of -85 i.e if signal is found to be stronger than -85 on the current channel then we should not do Tx.
We tried to set AGC_CS_THRESHOLd = 0x55(Hexadecimal) or 86(Decimal) but when we give it signal of -40 dBm shouldn't it trigger CCA as this input signal is greater(Stronger) then the threshold programmed but we have found that CC1200 still goes to Tx mode.
[1] How we can mange the proper threshold for CCA
[2] We have chosen 011 : Indicates clear channel when RSSI is below threshold and currently not receiving a packet
We don't have access to CC1200 dev kits
Please guide us. Thank you
