I was going through the Application Note for Antenna diversity in CC1310, SWRA523B.
- The measurements taken in the AN is said to be performed in CC13xxEM-7793_4L reference design, which is using RFP and RFN pins in differential mode for Tx and Rx.
- How could we implement the diversity in single ended mode with separate antennae at RFN and RFP ? Is the patch for the same available ?
- Is it possible for the developer to access the RF_core for applying the patch ?
Thank you in advance for any help you provide.
