CC1352P: Ti recommended baluns for high-power PA output
Part Number: CC1352P
Hi all,
In the datasheet of the CC1352P (SWRS192C) under section 7 Application, Implementation and Layout two balun IPCs are recommended for the high-power PA output of the chip.
I have not been able to find much documentation on these two balun IPC.
Is there any reference design / guidelines to be followed on their implementation to a new custom PCB based on the CC1352P??
Datasheets of the balun IPC:
https://www.mouser.de/datasheet/2/21/BD0826J50200AHF_DataSheet(Rev_E)-1221883.pdf
https://www.johansontechnology.com/datasheets/1720BL15B0200/1720BL15B0200.pdf
Max
